Page 42 of 95
Posted: Sun Mar 08, 2020 2:05 pm
by Phil Woollard
And back to the NBC box and the "tachos" 8)
Posted: Mon Mar 09, 2020 6:17 pm
by Phil Woollard
Busy day, got some of the turret roof weld beads out the way.
Posted: Tue Mar 10, 2020 1:44 pm
by Phil Woollard
Getting on with the turret detailing and there's a lot of it. 8)
Posted: Wed Mar 11, 2020 12:58 pm
by Phil Woollard
Cracking on with the turret and I've finally got those front fender rubbers mounted, we must also think about those who are being affected by the covid19 virus, Ivano stay safe my friend!
Posted: Wed Mar 11, 2020 3:10 pm
by John Clarke
Loving it, loving it, details so good and so daunting 8)
Posted: Thu Mar 12, 2020 5:52 pm
by Phil Woollard
Busy busy. 8)
Posted: Thu Mar 12, 2020 6:54 pm
by John Clarke
Let there be light said the electrician!
It's so tempting bang a COB lamp in the projector lamp housing, (The New hand held torches at work are blinding), I'll be on the look out for an old style rubber torch reflector and lens.
Self opening door would look classy via small servo behind reflector. Access from the rear and an opportunity to reduce the weight of the projector housing lump too. 8)
Posted: Thu Mar 12, 2020 7:53 pm
by John Clarke
Found an old rubber Ever ready torch in the shed!
It's close, but I'll still be on the look out for something a little bigger.
COB torches are so tempting, but the reflectors are usually small in diameter, marrying technology maybe.
The whole detailing bit on the projector make it look so much better, excellent work Phil. 8)
Posted: Thu Mar 12, 2020 7:57 pm
by Phil Woollard
That's not far off John, we still need some photographs for all internal detail fittings as well! 8)
Posted: Fri Mar 13, 2020 4:49 pm
by John Clarke
Phil, There's three pictures of the Light Projector in Chieftain, modern combat vehicles 1 by George Forty.
Projector Closed, Infra red filter present and white light only. Hope this helps.
Should be fun trying to get the doors and filter to work. :shock:
Posted: Fri Mar 13, 2020 5:00 pm
by Phil Woollard
How to detail the light projector rear for those who have never done it before. You could use metal sheet instead of plasticard but as this has a rigid backing support its just fine, and it's really easy to work 8)
Posted: Sat Mar 14, 2020 9:21 am
by Kevin Hunter
Another of your mini master classes which makes it look so simple Phil. I have to say that the change in appearance of that projector housing rear end is striking. Just adding such simple extras lifts this model to a different level.
Thanks for posting, we are all following in awe.
Kevin
Posted: Sat Mar 14, 2020 5:31 pm
by Phil Woollard
Busy day but enjoyable all the same, I thought I was just about finished with the outside of the light projector unit but I was wrong. Thanks to Malcolm Moananui for some cool photos that he sent me.
Posted: Sat Mar 14, 2020 5:54 pm
by Kevin Hunter
Phil, any use? Its not very clear I'm afraid.
Taken from MOD "Pamphlet 33 - Chieftain"
Kevin
Posted: Sat Mar 14, 2020 6:02 pm
by Phil Woollard
That's very useful indeed cheers Kevin !
