Panther G 2022 #15 Build
- Has liked: 382 times
- Been liked: 876 times
Re: Panther G 2022 #15 Build
A day off work and I managed to get a few hours of actual assembly in.
Several parts have now been installed that were waiting for the lower hull sides to be painted.
Next back to the suspension...
Already prepared a long time ago and now time to see about getting the flat ground onto those torsion rods and installed.
A quick check on the forum I think to see the best and easiest way to do it
2022 Panther G #15
Online
- Marco Peter
- Has liked: 1380 times
- Been liked: 779 times
This build is so clean it almost looks like a 3D render!
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
- Has liked: 252 times
- Been liked: 442 times
Hi Malcolm,Malcolm.Plumb wrote: ↑Mon Jul 03, 2023 6:19 pmA day off work and I managed to get a few hours of actual assembly in.
Hat's off to you stunning build.
Absolutely fantastic paint finish very crisp and clean.
Gary
Most of the day has been spent sorting out the suspension.
It worked out OK.
Now to get them painted.
It worked out OK.
2022 Panther G #15
A morning's work but got the suspension parts painted
2022 Panther G #15
That's the suspension all sorted and now on to the rear idler shaft and track tensioner.
2022 Panther G #15
A few hours put in today with the track tensioner finished and have made a start to the drive gear.
All parts cleaned up and gear case primed with a bit of texture added.
Red Oxide, topcoat and assembly hopefully tomorrow.
2022 Panther G #15
Another nice steady day with the build.
Gear cases in and have lightly primed parts of the rear deck. I have used Oxylube for the gears.
A lot of time was spent making spacers for the rollers so that the screw could be tightened down onto something solid instead of just the plastic of the roller.
Just a couple more days of my weeks holiday left now and back to work Monday.
2022 Panther G #15
- Chang
- Has liked: 15833 times
- Been liked: 425 times
Hi Malcolm , love to see your building.
Will you do anything about the mysterious hole ?
It was firstly mentioned by Gary Rafferty on 20 June : viewtopic.php?t=9311&start=180. Discussions followed , no definitive answer yet.
Puzzlingly not all batches of Panther have got this hole.
Lerh Chang
Lerh Chang
Hi Chang
No, not worried about it at all.
Can't be seen once the gear case is on nor can it be seen from the inside.
Malcolm
Malcolm
2022 Panther G #15
Just a little bit done today with the initial bolting together of the parts painted yesterday and another test fit of all the deck parts to recheck for a reasonably even clearance gap.
Not too many parts to fit here so I will look at getting this engine panel sorted.
2022 Panther G #15
A little bit of work carried out today on the rear deck/engine hatch assembly.
2022 Panther G #15
Started with some cleanup of a few M2.5 castle nuts tonight.
Pretty time consuming for 8 nuts but the Dremel helps a lot
2022 Panther G #15
Quite a few hours put into the build today
Managed to get the rear centre deck/engine hatch area sorted and prime the rest of the rear deck parts.
2022 Panther G #15
A few hours of work over the past couple of days with Prepping, priming and painting parts for the rest of the rear decking.
These radiator and fan cowlings are so much easier to paint when they are not fixed down.
Some weld beads and a bit more to do before I assemble everything.
2022 Panther G #15
