Yves Stug III update
florian rudolf
Has liked: 297 times
Been liked: 645 times
Re: Yves Stug III update
Post by florian rudolf »
yves mouton wrote:
Tue Nov 10, 2020 5:21 pm
Hello Florian,
I cut down the screws for the return rollers and the stug wheels and glue them in.
The bolts are M2 for the return roller hub caps
The bolts are M2,5 for the hub caps for the wheels.
best regards Yves
Perfekt I have enough M2,5 for the center screw ;)
yves mouton
Been liked: 699 times
Post by yves mouton »
Hello Florian,
The M 2,5 are for the six holes in the wheel hub caps, not for the center.
Regards Yves
florian rudolf
Ahhhh ok. What would you need for the center? Might be M3 if my remeber is right.
yves mouton
Hello,
Yes Florian for the center bolts of the return roller hub caps you nee a M3 bolt.
Today i used Tamiya surface primer for the wheels ( rolled surface )
For the body of the stug i use Mr surfacer 500 for a rolled surface.
First you bring on the surface primer 500 on with a brush and then dab it with a sponge.
Best regards Yves
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Mr surfacer is the best. Only downside is the intense smell 🙃
Keep the room ventilated 😁
cheers
Steen
yves mouton
Yes Steen mr surfacer is very good ,
but it smells a bit :roll: :roll: :roll:
regards Yves
Michael Röder
Has liked: 78 times
Been liked: 113 times
Post by Michael Röder »
Hello Yves!
Nice StuG bulid!
I'm looking forward to further detailing.
Regards Michael
yves mouton
Hello Michael,
Thanks for the compliments about the details on my stug.
There is still a lot to do.
Just waiting till the option packs will arrive. 8)
Best regards Yves
yves mouton
Hello,
Today i drill extra holes in the roof for the bolts.
I put 2 lifting hooks on both sides of the tower.
i put the return rollers on the hull.
I cut the front and rear of to fenders and put piano hinges on.
I will post later pictures because the image post side is unavailable for the moment :cry:
Best regards Yves
michael hilton
Has liked: 1566 times
Been liked: 835 times
Post by michael hilton »
Hello Yves, following your build with great interest. I like the 'surfacer', not used that myself, and your welds, keep posting, regards Mick.
yves mouton
Hello Roy,
I made my own tool for the welding, i will try to post soon a picture.
Regards Yves
yves mouton
Hello ,
Post image works again so here are my new pictures.
I orderd also flat brass 2 mm / 5mm /2m to make a rack on the rear of the stug.
I also wanne try to make the holders for the sideskirts to protect the wheels, i have saw on the forum a guy
who made them but i cant remind his name.
Maybe someone can help me find this guy, i wanne ask him the mesurements for those skirts and holders.
Best regards Yves
Roy Beukeveld
Has liked: 171 times
Been liked: 118 times
Post by Roy Beukeveld »
yves mouton wrote:
Sun Nov 15, 2020 6:19 pm
Hello Roy,
Regards Yves
Hi Yves, I would like to see it, thank you very much :)
Nice progress on your StuG today, the wheels and the welding look very nice!
Kind regards,
Roy
yves mouton
Hello,
Today i put 2 extra pins in each wheel.
I also started on the fenders
And i put the tracklink bar on the tower and the smoke dischargers.
best regards Yves
yves mouton
Hello,
A little update again but a lot of work on de rack for the stug.
Made from brass 2mm tickness and 5mm width. Bolts used M 2,5 on the hull, put the rack together
with rivits .
Best regards Yves
