Page 5 of 7
Re: Martin's Elefant
Posted: Mon Oct 05, 2020 4:33 pm
by Martin Hofmann
Hi Simon,
the Zimmerit around the cone head bolts are also very tricky
Posted: Mon Oct 05, 2020 8:06 pm
by Robert E Morey
Martin,
Excellent work on the zimmerit. I think milliput makes the best zimm, but not the easiest stuff to work with. Looking great!
B
Posted: Tue Oct 20, 2020 4:51 pm
by Martin Hofmann
Hi Bob,
Thanks - you are absolut right - Milliput makes the best Zimmerit.
Here some more impressions of that with some welding seams.
Posted: Fri Oct 30, 2020 3:47 pm
by Martin Hofmann
The mud scrapers are welded onto the hull.
And the Zimmerit is also done on the other side....
Posted: Fri Nov 06, 2020 4:21 pm
by Martin Hofmann
Now all Zimmerit is done on the rear side.
A little bit weathering and some exhaust soot on the underside of the track plate.
Posted: Tue Nov 17, 2020 5:11 pm
by Martin Hofmann
During mounting of the covers for the sprockets i saw, that the cone head bolts are a little short. Only 1mm longer as the thickness of the cover - after mounting the safety tab washer. So i decided to short the bolts about 3mm and use a distance bolt with inner and outer diameter of M3. Also i countersunk the covers with dia of 6mm to hidden the brass bolts. So it will be no problem to screw the cover onto the sprockets.
Posted: Mon Nov 23, 2020 5:07 pm
by Martin Hofmann
Now it is time to make a construct for the batteries and the loud speakers.
Therefor i cut some steel bars and L's for welding a frame mounting on the lower side walls.
Posted: Fri Nov 27, 2020 3:09 pm
by Martin Hofmann
After mounting the battery frame it looks like this.
The front part is ready for Zimmerit, the diamond plates are bonded and the holders are screwed on.
Posted: Sat Nov 28, 2020 8:45 pm
by Christoffer Ahlfors
Perfection as usual!
Posted: Fri Dec 04, 2020 3:54 pm
by Martin Hofmann
Hi Chris,
thanks for the nice words. Now the Zimmerit is done onto the front.
I couldn't help, but i modelled the same welds for the jacks like Steve, remaining to the Ferdinand before.
Also seen at the Bovington Elefant
Posted: Fri Dec 04, 2020 5:03 pm
by simon_manning
SUPERB ! Regards simon.
Posted: Fri Dec 11, 2020 5:06 pm
by Martin Hofmann
Hi Simon,
many many thanks for your nice word: SUPERB
now i was adding some small screws at the diamond plates. After the first coat of paint, the Elefant looks completely different.
Posted: Fri Dec 11, 2020 5:09 pm
by Robert E Morey
First class job on the details and zimm. Looks real 1:1. Very nice!
Posted: Mon Dec 14, 2020 5:12 pm
by Martin Hofmann
Hi Bob,
thanks for the kind words.
Now it is time to mount the swing arms and all the road wheels.
Of course you shouldn't forget the grease nipples
Posted: Fri Dec 18, 2020 5:02 pm
by Martin Hofmann
After weathering the road wheels are looking very "used".
Now i start with the fighting and motor room.
