Martin's Elefant
Martin Hofmann
Has liked: 151 times
Been liked: 1997 times
Re: Martin's Elefant
Post by Martin Hofmann »
Hi Simon,
the Zimmerit around the cone head bolts are also very tricky :D :D :D
Regards Martin
Has liked: 161 times
Been liked: 830 times
Martin,
Excellent work on the zimmerit. I think milliput makes the best zimm, but not the easiest stuff to work with. Looking great!
B
Martin Hofmann
Hi Bob,
Thanks - you are absolut right - Milliput makes the best Zimmerit.
Here some more impressions of that with some welding seams.
Regards Martin
Martin Hofmann
The mud scrapers are welded onto the hull.
And the Zimmerit is also done on the other side....
Regards Martin
Martin Hofmann
Now all Zimmerit is done on the rear side.
A little bit weathering and some exhaust soot on the underside of the track plate.
Regards Martin
Martin Hofmann
During mounting of the covers for the sprockets i saw, that the cone head bolts are a little short. Only 1mm longer as the thickness of the cover - after mounting the safety tab washer. So i decided to short the bolts about 3mm and use a distance bolt with inner and outer diameter of M3. Also i countersunk the covers with dia of 6mm to hidden the brass bolts. So it will be no problem to screw the cover onto the sprockets.
Regards Martin
Martin Hofmann
Now it is time to make a construct for the batteries and the loud speakers.
Therefor i cut some steel bars and L's for welding a frame mounting on the lower side walls.
Regards Martin
Martin Hofmann
After mounting the battery frame it looks like this.
The front part is ready for Zimmerit, the diamond plates are bonded and the holders are screwed on.
Regards Martin
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Perfection as usual! :D
Martin Hofmann
Hi Chris,
thanks for the nice words. Now the Zimmerit is done onto the front.
I couldn't help, but i modelled the same welds for the jacks like Steve, remaining to the Ferdinand before.
Also seen at the Bovington Elefant :D :D
Regards Martin
SUPERB ! Regards simon.
Martin Hofmann
Hi Simon,
many many thanks for your nice word: SUPERB :D :D :D
now i was adding some small screws at the diamond plates. After the first coat of paint, the Elefant looks completely different.
Regards Martin
First class job on the details and zimm. Looks real 1:1. Very nice!
Martin Hofmann
Hi Bob,
thanks for the kind words.
Now it is time to mount the swing arms and all the road wheels.
Of course you shouldn't forget the grease nipples :D :D :D
Regards Martin
Martin Hofmann
After weathering the road wheels are looking very "used".
Now i start with the fighting and motor room.
Regards Martin
