Chieftain Stuff
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Re: Chieftain Stuff
Post by Mark Heaps »
Hi Dave,
Both look good but if you had the BV full of boiling water, you were hardly likely to open the lid due to the steam and if you suddenly hit a bump, scalding hot water flying everywhere.
Best would be the top depicting the BV insert about 80% full of water and four compo cans sticking out, 60% and 3 cans, 40% and 2 cans.
Lid was opened to fill with cold water, put food in or take it out.
Mark Heaps
Re: Chieftain Stuff
And the thinner wire is too glossy. The previous wire had the perfect colour.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Re: Chieftain Stuff
Post by Kevin Hunter »
Grief..... give the man a break :oops: :oops: :D :D
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Re: Chieftain Stuff
I'm going to have to complain to Ebay that that they don't do the right size wire in the right colour/sheen You won't get the wire with it anyway so you pick your own colours. I' can't now see the point in sodding about with thin detail castings making my own life difficult for no real reason so I'll be redoing the master with a closed lid. The BV will be a solid resin casting.
Dave
www.armorpax.net
Chris Hall
Has liked: 536 times
Been liked: 688 times
Re: Chieftain Stuff
Post by Chris Hall »
Don't let unreasonable criticism get you down, Dave - the vast majority of us appreciate your output and attention to detail.
And, on that topic, any update on Lee / Grant bits ? Cash waiting ...... :)
Keeping smiling,
Has liked: 1040 times
Re: Chieftain Stuff
Dave, do you ever get the feeling a little knowledge is a dangerous thing? Your work on the Chieftain parts is exceptional craftsmanship and well worthy of the model itself. Crack on and give us all more to admire and buy. I loved your Mulligatawny anyway and the other bits. I couldn't pass by though without sparing a thought for our old friend Mr Larkspur. Long time no see........
Mark Heaps
Re: Chieftain Stuff
Dave,
My input was meant to be constructive and I apologise if you saw it otherwise.
How ever you do do them, I will be ordering a set, as soon as you post that they are available.
Kindest regards
Been liked: 1844 times
Re: Chieftain Stuff
Dave, don't worry we all love what you do.
Your a true artisan. 8)
There's a lot of truth in the words "Perfection is the enemy of Excellence"
I'm with you Stephen, looking forward to the Larkspur and of course the shopping list.
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Re: Chieftain Stuff
Post by Richard Goodwin »
Ditto Dave even if your not doing the Stillbrew! Am I the only one that would like Clansman? Having trained to repair both of them, I do need a Clansman version for my model if at all possible please?
Re: Chieftain Stuff
Agreed. The conversion from Larkspur to Clansman was done during Base Overhaul over a period Starting in 1976, so both are appropriate. My long-standing request to Dave to do Larkspur is for my Centurion. Dave already does a Clansman antenna base, so if he were to give us a full house, it would be for Larkspur antenna base and commander and operator ancillaries for both. For Larkspur, that would include two types of breastplate, headphones and mike. For Clansman, we initially used the pressel unit and Headset, VRC (aka Staff User Headset) with attached boom mike, then the Helmet Crewman AFV (which Dave’s already onto), and finally the Headset, A Vehicle, with protective shell. I don’t think the latter would be either necessary or easy to do but that’s a decision for Dave to consider. Whatever Dave produces will be outstanding and beyond what most of us can achieve. Thanks Dave.
Re: Chieftain Stuff
Hi All,
I've painted the lead and added a couple of yellow sleeves to each which appear on a number of on-line pics of leads. Based on the Marks post I can't see many people realistically having the BV open so will produce a solid version unless anyone feels an opening version is wanted?
I'm going to start making some new moulds tomorrow based on my own Clansman aerial base and the new master for the Larkspur base sent to me by Stephen. The aim is to offer both mounts with with a black flexible resin section to represent the original rubber portion. My current base is the MK6 with quick release for the rod, can anyone confirm please that the MK2 will be more suitable for Chieftain similar to the wing nut retainer on Larkspur. I have also started work on the BCF extinguisher bracket and hope to have that done in the next week. I will then turn my attention to the GPMG mount for the cupola.
The other parts planned when I can get time are the Wiper assemblies for the cupola, the commanders searchlight, Clansman commanders breast plate (Larkspur already done) and the Bone dome. I will be doing the Larkspur handset for Cent owners.
Dave
www.armorpax.net
Kevin Hunter
Re: Chieftain Stuff
Great stuff Dave.
Re the BV, closed suits me but I’ll go with the flow. Looking forward to seeing the other projects as you get to them.
Also nice to know there’s some Cent stuff in the mix.
Kevin
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: Chieftain Stuff
Post by Steve Norris »
Dave
Great job with the BV but surely it lives internally and so would not be seen on the Chieftain unless your doing a full interior.
Re: Chieftain Stuff
Maybe Steve but I've already sold some and not for Chieftains ;-) Sometimes its just because I fancy making something. The No2 burner was another ;-)
Dave
www.armorpax.net
mark lawson
Has liked: 2523 times
Been liked: 445 times
Re: Chieftain Stuff
Post by mark lawson »
Excellent work on the BV Dave, this would be an excellent addition to any model especially if one can open and close the lid regardless of jobsworth regs.
RAG Militärmodellbau
IG Militärmodellbau
