Hi All,
Update 5 Mar 21
I decided that it was important, as I am planning to have animated fan units, to improve the accuracy of the engine deck grillwork.
Radiator outlet grills
First, I cut the bars to match those found on the actual vehicle.
I also milled off the integral hinge and replaced it with a set from Sixth Scale Icons (from Field of Armor)
Using a resin set obtained from John Grima (East Coast Armory) I increased the thickness of the grills to make them more proto-typical.
Resin part will be pinned using 1.6mm brass rod. The actual castings had end ‘caps’ that joined the bars together. This was made from laminated Plasticard that will be pinned to the resin part during final assembly.
Part complete, ready to be pinned and glued to the cover.
Part epoxied and joints ‘smoothed’ with Milliput.
The bottom detail consolidated with several stippled coats of Mr Surfacer 500.
Radiator inlet grills
Standard part
Resin piece from John. This was thinned down to a height of 6mm to ensure the correct overall depth.
Piece adjusted, pinned and epoxy glued to pre-primed cover.
Adding edge detail using Plasticard, also pinned, using 1mm brass rod this time.
The bottom detail was consolidated with several stippled coats of Mr Surfacer 500.
Finished item prior to priming (red primer)
Fan Units
These have been completed and dry fitted to the radiator covers
Assembly fitted in place. The cap screw heads will epoxied into the radiator cover and blended out using a suitable filler; Milliput or an automotive glazing putty.
General view giving idea of final look.
Thanks for viewing
Alastair
