OPEN ON THE 6TH FEB 2025
Phil Dawe
Has liked: 755 times
Been liked: 298 times
Post by Phil Dawe »
Vince Cutajar wrote:
Thu Jun 27, 2019 11:40 am
Very nice collection of after-market parts.
Would love to know the provenance of the MG.
Is the rifled tube from across the pond?
Vince,
The MG34 is Dragon and we got it new on eBay Bought it for about £50 if I remember correctly. They do a cheaper plastic one but its not as durable. The vendor was here in the UK
Hope that helps!
Has liked: 775 times
Been liked: 1740 times
the barrel insert did indeed travel across water!
Thanks Phil and Phil for the info.
Will be interesting to see (when you get to it) if the rifled insert is a good fit with the inside of the barrel.
Has liked: 129 times
Been liked: 773 times
Hi Phil I will be following your build with interest. I'm late to the game (your thread) because you work so fast. Are you planning on lowering the rear deck plate and rear deck?
Best regards, Bob
Has liked: 2267 times
Been liked: 7152 times
Hi Bob, ref the rest deck, I suppose I will have to! 8)
It's amazing just how much work is involved with the Tiger 1 rear plate and fittings. 8)
I have made a start on the tracks
There's a long way to go with the fender kits, sooo many small parts but beautifully reproduced.
The jack does look the business.
florian rudolf
Has liked: 294 times
Been liked: 640 times
Post by florian rudolf »
Phil Woollard wrote:
Thu Jun 27, 2019 10:24 am
I do have an old fashioned work ethic I suppose, if someone works for me I want value for money and vice versa but keeping up the quality!
Thought you guys might like to see some of the gucci parts, I'm sure you all know where they come from.
Hi Phil,
sorry don't know the factruy of these nice parts. Ould you tell me please ;)
Hi Florian, I will let the other Phil (the boss) explain all, the suppliers need some recognition so they can carry on making these wonderful upgrades! 8)
The engine bay detailing will be one to watch also.
florian rudolf
ok thank you.
Glad to see more ;)
Up date, the nice cloth and metal gurtsack and superb ammo belt is on order. The oh so intricate rear fenders, the fixings are about as small as I want to work with. There are no extra of the tiny rivets so you have to be careful that one doesn't "ping off" and just a couple spare of the .80 countersunk screws, I must say that the screws are of very good quality, this helping the location of the nut on the thread for the first time.
Very small fixings with the nicely made fender kits from the icons range.
That's a m3 standard hex for comparison, the fixing must be very close to the correct scale size.
The hinges are fiddly but the brass is thin and has been annealed
If you take your time rolling the hinges very carefully you should end up with a near perfect  functional fender.
The cross heads on the hinge mounts will be hidden under zimmerit. The fender hold up arms can't be fitted until I have installed the upper hull sides.
As the Tiger will spend most of it's time in a museum I have left the fender hinge pins long by just enough to be able to conveniently remove them for general manoeuvring of the vehicle ( as they are very delicate) they can then remain intact and replaced for exhibition.
The starter plate all finished this morning so convoy light next then the starter handle stowage when that arrives and the rear is all fitted out.
Phil Dawe
Post by Phil Dawe »
florian rudolf wrote:
Fri Jun 28, 2019 8:22 am
Hi Phil,
sorry don't know the factory of these nice parts. Would you tell me please ;)
Florian,
The detailing parts were sourced from the following manufacturers:-
The Late Mike Stannard (via Martin Diessel)
Armorpax (Dave Dibbs)
Steve Winstone
Mark Lawson
Tim Catton
Field of Armor (USA)
East Coast Armor (USA)
Rather than list every single part and where they came from, if there is a particular item you wish to know about, just let us know.
Back to the big bits for a while. Now I have to think of a way to allow access to the inner hull whilst installing a complete engine bay, radiators, radiator fans , engine, fire wall, fuel tank shield/ducts, smoke system, the associated wiring loom and all the engine bay plates, oh and the speakers.
All this needs to be removable as a unit, at least while I'm working on it..... should be interesting. 8)
A lowered deck! The deck needed some "tin bashing" to get it flat and true.
All the plates go together ncely
A bit more done, I have put off the milliput for as long as I can but must now knuckle down for a marathon of sausage rolling.
A mod that I need to do as the engine bay and the fan drives will cover these important areas, if the idler m6 cap head should pop out it's recess, the whole engine bay would need to be removed, so this simple stainless cap will hold everything secure, the m3 cap is drilled and tapped into the rear plate.
"Run of the mill" masking for the hull interior paint.
Very white but will be weathered accordingly.
I think we will go for a grey engine compartment
Glen Clark
Has liked: 19 times
Been liked: 160 times
Post by Glen Clark »
I wish I had gone for Grey Phil,it may not be correct but it's a lot easier on the eyes through the grills and hatches.
Not that mine is correct in any way but it is ok to me.I do really love your build and attention to detail.
Glen.
She looks good Glen, maybe paint that engine bay that won't take long!
