Yves Panther A update
yves mouton
Been liked: 741 times
Re: Yves Panther A update
Post by yves mouton »
Hi Phil,
If you take the speakers out of the speakerbox, dont you loose
the depth of the sound?
regards Yves
Has liked: 2282 times
Been liked: 7196 times
You cant quite see the speakers in these photos but they are there under the fuel tanks tucked between the engine bay walls and the hull sides :D
The area of the engine bay/fuel tank void gives you the speaker box effect.
yves mouton
Thanks for the info Phil
regards Yves
yves mouton
Hello,
Today wheel treatment with Tamiya surface primer the other jar is mr surfacer 500
is for the body of the panther, this treatment gives a rolled surface.
Made also the smoker and test fit.
Tomorrow i am working on the deck grills.
Regards Yves
yves mouton
Hello,
Here are a few new pictures of my build,
make the rear deck grills.
Made also the hole for the smoker switch and the battery charging plug,in the
Steve Winston stowage bins.
Also put the rubber tires on the wheel with Loctite nr 480
Best regards Yves
Very nice work as always Yves, regards Phil. :D
yves mouton
Thanks Phil,
Still have a few days free to work on the panther ( vacation ),
monday have to go to work again :( :( :( :( :( :(
regards Yves
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Really neat work Yves, I am following your build with great interest.....Mick
yves mouton
Thanks Michael
regards Yves
yves mouton
Hello,
Some small progress, welding on the hull and rear deck,
rear deck is not yet completely finished.
Best regards Yves
Nice technique with the weld detail, better than mine, very neat :D regards Phil
yves mouton
Thanks Phil
:roll: :roll: :roll: :roll:
regards Yves
yves mouton
Hello,
After a long long time i started back on my panther, here are some new pictures of my build.
Work on the suspension bars
Work on the towing hook
made some detail on the mantled and barrel end
i used mr surfacer 500 on the mantled to get a rolled surface.
All my other pictures are gone , there is a image icon instead??? :? :? :?
Best regards Yves
mark lawson
Has liked: 2519 times
Been liked: 444 times
Post by mark lawson »
Yves you have used the wrong links for your pictures
RAG Militärmodellbau
IG Militärmodellbau
yves mouton
Hello Mark, i know but if i used the other url, the pictures are to small.
Regards Yves
