2013 King Tiger
Roger Sleep
Been liked: 41 times
Re: 2013 King Tiger
Post by Roger Sleep »
Update on my build
Hub's all primed with etch primer and base coated
Front deck and hatches all assembled etched primed and base coated
Turret roof assembled with a few scratch built part's added and plenty of weld's added :evil:
Muzzle brake modified etched primed and base coated
Been liked: 1643 times
Re: 2013 King Tiger
nice details rodger, your muzzle brake looks real, the build is coming along well, after looking ay your muzzle brake my lock washer is too thick on mine, i forgot it bends in to the grooves on the lock ring, next job on the lathe, regards simon manning.
Roger Sleep
Re: 2013 King Tiger
Thanks all for comments and advise
Regards Roger
Paul Wills
Has liked: 646 times
Been liked: 141 times
Re: 2013 King Tiger
Post by Paul Wills »
Hay Roger,
She is cumming along nicely and as Simon said, that's a great bit of work on your muzzle brake 8)
Paul. :wink:
Roger Sleep
Re: 2013 King Tiger
Thanks Paul,can't wait to get it finished,its been a long haul :D
Regards Rog
Roger Sleep
Re: 2013 King Tiger
Update on Pannier sides, all the fake weld's are done,what a tedious job that was glad that part is done, all ready for a base coat
Paul Wills
Re: 2013 King Tiger
Hi Rog,
Haha, I know what you mean about it being a long haul. my 88 seams to be taking a lifetime :lol:
Nice welds, you've got them off to a T. I've got to redo the welds on my Tiger 1 when I get back to its refit, and then its on to the KT. I think I will be 90 by the time I've finished :shock: :lol:
Paul.
Roger Sleep
Re: 2013 King Tiger
Cheer's Paul looking forward in getting it finished, just takes a long time when you have got loads of other job's to do around the house
Regards Roger
Roger Sleep
Re: 2013 King Tiger
Hi all having a go at making some periscope prism's for the driver and radio operator out of perspex, and then gluing perspex mirŕor to the angled perspex,worked out really well,
As you can see it's hard to get good pictures will try and get some more done on the weekend
As you can see the reflection from the text is in the mirror part of the prism
Pierluigi Patri
Been liked: 1 time
Re: 2013 King Tiger
Post by Pierluigi Patri »
Hi Roger
I think the prism is an excellent result that allows a perfect view.
Did you make it by yourself?
There is only one type of perspex to use?
How did you get a so shiny surface?
Pierluigi
Roger Sleep
Re: 2013 King Tiger
Hi thanks for the coment a few more pictures as promised,
As for polishing the perspex I went through the grades from 240 grit 400, 800, 1200, 1500, 2000 wet and dry and then polished with a cuting compound ie,T cut for polishing paint on cars, then laminated the perspex mirror to the angled perspex, with perspex glue
Hope this helps but it's not an easy job
Regards Roger
Paul Morris
Been liked: 68 times
Re: 2013 King Tiger
Post by Paul Morris »
Hi Roger.
Very well done impressive :)
Cheers Paul. :wink:
01524 720977
Tim Page
Has liked: 40 times
Been liked: 469 times
Re: 2013 King Tiger
Post by Tim Page »
Well done Roger, very impressive.
Pierluigi Patri
Been liked: 1 time
Re: 2013 King Tiger
Hi Roger,
many thanks for the reply and the technical warning.
Pierluigi
Roger Sleep
Re: 2013 King Tiger
Hi all, update on my build all had a coat of Base coat, next job camo and periscopes
Here are a few pics on my progress
Regards Rog
