I have gone for 33 amp hour which are the size John used in his Comet.
It needs a bit of a shift round of the electrics but will give a longer running times.
____________________________________________________________________________________ Interested in animatronics for your tank? Contact me at westfrontcustoms@gmail.com | See examples at http://westfrontcustoms.nl
Hi Guys
Not much to report but I have been changing the crimp eyes
on the battery leads as the terminal bolts are bigger on the
33 amp batteries than the normal 22 amp ones that Armortek
design the electronics round.
These are things to think about when we make these changes
Hi Guys
This is the electrics going in and as you can see I am going to try and keep power on one side
and the signals on the other.
The new batteries have made me move things arround so the aux unit electric is in the front
under the power unit,
Because of this I have had to make long leads to connect the speed control unit.
hello Derek,
here are some pictures of my old comet, there is no room left inside once all the electrics are in, don't forget to leave room for the smoker, that was the hardest to make room for,
Congratulations Derek, she looks magnificent. The work you did on the turret front lip really pays off - I was going to stay stands out.... The electrics look a really tight fit, well done for squeezing it all in so neatly. Looking forward to seeing her running.
I'm anticipating the day when I can get back to my Celerity from 3 RTR, it's a fine kit.
