UPGRADES ON T34-85 KIT
- Been liked: 53 times
Re: UPGRADES ON T34-85 KIT
…..Continuing on with my Upgrading progress on the T34/85 Tow Ropes.
Primed now, and Just need to weather them before I add them to my tank.
Ian
Ian
- Been liked: 68 times
Hi Ian.
I like every single bit you have added to this model it looks a real treat
Cheers Paul.
Cheers Paul.
01524 720977
01524 720977
Hi Paul,
I'm happy to know that you like every single upgrades I have added to my T34/85 tank, and a real treat too.
"Praise indeed" from the master builder yourself………
It's certainly has been, and still is a most enjoyable project to work on, so different from working on the usual German tanks.
However once I'm completely finished all my upgrades for the T34, it will be time to return to my unfinished Panzer III…..+ adding even more upgrades to this model.
Thanks for your nice comments, much appreciated for sure…...looking forward to seeing your latest creations coming out of your own work shop!
Ian
Ian
Hi All,
Just adding a few pics on my latest upgrade for my T34-85 kit. Before Armortek new website comes along!
This time I had a go at making a few Ice Cleats to add to my side mudguards, although I'm not sure I will ever try them out on real snow and ice, attached to my T34 tracks.
At the moment they will just be for show.
Still to make the straps to hold them in place.
Ian
Ian
Nice work on the ice cleats, Ian.
I am going to have to make a set myself.
I really like all the pictures and drawings, this really helps me make these parts. I already used your pictures to make my hammerhead style tow hooks.
William
William
Thanks William,
Although I made 12 ice cleats, might be to many to attach onto my side mudguards, but rather make too many than to to few……
I'm still looking at my T34 books and on the websites to see which way the ice cleats were facing! when they were attached to the tracks. If any body has got a clue, please let me know!
As for my sketches, they are just for researching and getting to know my subject matter…..
Happy to know my drawings helps you out in making your own parts.
Yes the tow hooks were fun to make out of a solid block of soft metal or aluminium!
In fact I used the larger long block (box A) that Armortek had to represent the side boxes that sat on the side of the T34-85 Mudguards.
Ian
Ian
- Has liked: 146 times
- Been liked: 806 times
Ian,
Fantastic work on the smoke "cans", tow cables, and ice cleats. They are a marvel of ingenuity, skill and craftsmanship. Still loving the concept sketches as well. How do you install the cable in the ends of the tow cable ferrules?
Fantastic all around.
- Been liked: 48 times
Great job!
I can ask if they are made of aluminum? And in this case, how did you solder the parts?
Thank you!
Ciao,
Iacopo
Thank you!
Ciao,
Iacopo
Hi Robert & Lacopo,
Thanks for your nice comments, much appreciated.
In answer to your questions on tow cables and ice cleats.
If you look at the pic I attached of aluminium rod about 6mm in width I used for the ends of my tow cables by cutting up in 10 to 15mm in length, drill the right diameter size hole down through the centre to fit in the cable ends, then using a superb glue I use a lot on my tanks this wonderful stuff called Loctite Hybrid Glue, works really well, same glue I used for gluing my (72) teeth onto my right angled aluminium ice cleats. I did not use any soldering to fix the teeth in place.
I don't think I will try out my home made ice cleats for real on my T34, as I'm sure the pressure would be to much for the cleats!…..made only for displaying on my side mudguards. Same goes for my tow cables, only for display, not for pulling the tank!
Hope above answers your questions, if not come back to me!!
Ian
Ian
Hi All,
Just adding a few pics of some of my tools for my T34-85 tank.
Crowbars and Hammer
Ian
Crowbars and Hammer
Ian
Hi Guys,
Just some more upgrades to add to my T34-85 Tank.
This time the log and clamps attached.
Ian
Ian
Hi Ian.
Once again great stuff mate very impressive from start to finish well done
Cheers Paul.
Cheers Paul.
01524 720977
01524 720977
Thanks Paul for your nice comments, just one or two more upgrades to add, then I will need to try and get my T34 mobile……!
Ian
Ian
Hi Folks,
I'm back with a few more finishing touches to my Tow Ropes and Smoke Canisters for my T34-85 tank.
Ian
Ian
- Been liked: 1720 times
as said before a superb build and hand written instructions as a bonus, the t34 looks the buisness, enjoyed the posts all along, regards simon manning,
