Page 5 of 7
Re: A34 Comet Mk I Type A - New Build
Posted: Mon Aug 06, 2012 10:44 am
by Stephen White
Thanks Adrian and Steve. The early pattern idlers are 85mm in external diameter and the tyre rim is 21mm wide. Probably a very bespoke size for any commercially available tyres? I did think of moulding but it would be a lot of effort for four off and I'm not familiar with the materials. I did think that the pressure of the track would tend to retain the tyre on the rim but any lateral forces could be a problem. That's why I chose to replicate the inner rims as per the real thing. They weren't difficult to turn, at least not in comparision to the internal shapes. Thanks for the interest Stephen
Posted: Mon Aug 06, 2012 2:44 pm
by Simon Peck
Hi Stephen.
Very interesting work you are doing! Just a thought, I don't know if it would work, but could you make the 'tyres' from round black nylon rod? You could turn it to the exact size on your lathe. I know it's not rubber, but it would be durable.
Simon
Posted: Mon Aug 06, 2012 3:04 pm
by Paul Morris
Hi Stephen.
Just a thought what if you could get hold of a "sample" of black rubber hose / airline or hydraulic pipe that was just about the right size and force it over a mandril and then turn the tyres on your lathe? I know it would be pot luck to find nearly the right size but might be worth 20 mins looking
Cheers Paul
Posted: Mon Aug 06, 2012 6:53 pm
by simon_manning
inspirational comet building, great to follow even though i do not own one, but would like to, keep the progress coming stephen, regards simon.
Posted: Mon Aug 27, 2012 8:33 pm
by Stephen White
Thanks guys for the interest and kind comments.
Last pics of the finished replacement idlers with hub caps detailed:
Now for the hull outer side plates which have a lot of detail to add. Firstly the side plates were made up from five seperate pieces so the joins were milled out. Then shape of the cut outs which allow the suspension to travel were corrected. The real ones were deeper with rounded corners. There are something like 150 hex head bolts on the sides, so the fastner suppliers are in for a bonanza:
Posted: Sun Sep 02, 2012 9:23 pm
by Stephen White
A large bag of 7BA hex head set screws has arrived so no excuses.......
Marking, centering, drilling, they certainly didn't design the Comet for ease of production. Firstly the surface prep - several coats of UPol High Build Primer in a random pattern followed by some work with the miiling burr.I've decided to do a section at a time, for variety. So here is the first, with the distinctive bolt patterns:
Posted: Sun Sep 02, 2012 10:43 pm
by Steve Stuart
A week of rain has helped you drill how many holes?!
And for interest, what size of bolts are you using?
All the best, Steve
Posted: Mon Sep 03, 2012 12:05 am
by simon_manning
perhaps the chief designer of the comet had shares in a nut and bolt company, exacting work stephen and well done, regards simon.
Posted: Tue Sep 04, 2012 4:48 pm
by Stephen White
Thanks both. I keep thinking of the aircraft workers you see in wartime films rivetting up structures or the ship builders doing the same with bigger rivet guns. I suppose you get into a rhythm.
Steve - 253 to be precise and I've used 7BA hex heads. They are within a couple of tenths of a millimeter of the real scale size, closer than 8BA which do look too small.
All the best.
Posted: Tue Sep 04, 2012 11:47 pm
by Steve Stuart
253 is a bit daunting, however 7BA fits in with what I have used elsewhere, so that is good confirmation! On another note, one of the Isle of Wight Tank Museum Comet hulls some of the 'bolts' are countersunk, is this a later adaption? In other words a B variation.
- Comet Hull Side Plate
Posted: Sun Sep 30, 2012 10:31 pm
by Stephen White
Some work on the side panels - different textures to highlight the individual panels, all trying to simulate rolled armour plate:
The axle covers were slightly recessed as here:
So some milled rebates:
Posted: Sat Oct 13, 2012 7:26 pm
by simon_manning
coming on a treat stephen, always interesting, regards simon manning,
Posted: Sun Oct 14, 2012 9:57 pm
by Stephen White
Simon, good to know you're out there. Your JP is looking quite stunning.
More random work on the outer hull sides. Photos from Fabrice of the Isle of Wight Comets made me realise that the cutouts for the suspension travel have a small chamfer cut out - it's not on the original wartime drawing:
So revised shape:
The more I use UPOL High Build Primer, the better it gets for re-creating rough rolled armour plate and castings. I spray several random layers and then use the Proxxon and different milling cutters:
Completed adding the external bolts and assembled the return roller housings. The end of the shafts should have a central hole and two chamfers:
A few minutes with the milling machine:
Some general views of the outer hull side, loose fitted to the inner:
Posted: Sun Oct 14, 2012 10:36 pm
by simon_manning
my jp is like skipping over the surface of building, this is nuts and plenty of them, i did'nt realise the comet level of detail, superb! regards simon,
Posted: Mon Oct 15, 2012 11:11 am
by Dennis Jones
Brilliant work Stephen. Just starting my Tiger but it won't have that amount of detail but I am hoping to get a lot of working extras on this one as plenty of room in the hull, recoil and muzzle flash, m/c gun flash, opening hatches under r/c, moving figures and smoke of some sort. Keeps the public happy cos as you are aware I am a demo man.
Dennis.
