Luca,
So sorry to hear of your troubles moving the tank about. They are not light and moving them takes planning and resources for sure. That is one beautiful model though, someone will be very lucky to have it. I wish you the best in its sale.
Ultimathe Panther by Luca
- Has liked: 132 times
- Been liked: 784 times
- Been liked: 177 times
- Chang
- Has liked: 16068 times
- Been liked: 454 times
I was misunderstood Chang, the 12 V engines is just because how are arranged the speakers it looks like so. Batteries are wired in series to have 24V in total.
The strange black switch it's only a fuse's container, the main wire coming from the battery have a fuse before entering in the starter unit.
This system could be useful when you plan of don't use the tank for long, it's enough to remove the fuse and your electronic is separated from the battery, also useful during the recharge.
The two speaker can't be positioned over the tracks, as was possible in the KT, because here we don't have the right highness.
The only solution to fix them seems to be a bracket starting from the floor, the speaker is fixed to the staff by using its rear screw, they are not glued onto the chassis.
Luca
Luca
