OPEN ON THE 6TH FEB 2025
Tiger 066 Construction
John Grima
Been liked: 48 times
Post by John Grima »
Thanks guys,
Lee, with the paints I use the Varnish is not needed.
I'm currently working on the tools. I should have them ready and installed by early next week.
leesellars
Been liked: 15 times
Post by leesellars »
Hello John
What paints are you useing. I use Tamiya and vallego.
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
John Grima
I use Tamiya for some of the paint work. For the rest I use my own mix of latex paints.
The the last of the tank's components have been added completing the tank.
For the tank's tow cables the kit supplies you with pre cut and pre assembled steel tow cables and transport cable. The cables were a perfect fit to my revised tow cable locks and were simply painted, weathered, and mounted to the tank.
For the tank's gun cleaning rods the kit supplies you with several wood dowel rods, and CNCed Brass end tips. The kit parts were also nicely done and were used. The rods were treated and the brass rods were painted and weathered.
The kit supplies you with an Armorpax resin German AFV fire extinguisher. The part is nicely detailed and casted. The component was simply painted and installed with no mods.
Another Armorpax component that the kit supplies you with was the German AFV Jack. Like the fire extinguisher the jack was nicely made and was built out of the box and mounted to the tank.
The kit supplies you with two cast bronze tow claws. These needed no mods and were used as is.
The kit supplied crank shaft and crow bar were also used. The crow bar needed a small tweak. The kit supplied bar has a flat end with a machined brass tip. On the real component the tip was flat with a bend. This was quickly added to the kit rod. Once done they went into painting and were mounted.
for the other hand tools the kit supplies you with a set of Armorpax white metal German AFV tools. The only mod that was made to the tools was the replacement of the supplied metal handles with scratch built wooden ones.
The tank supplies you with a pre cut block of wood for the jack block. The block was the correct size and shape and was a good base to add the details.
The tank's antennas have been scratch built and added. The sternantenna was fabricated out of turned brass and aluminum. All components had to be made out of metal because the antenna connects to the tank's radio receiver and extends the tank's radio range. The only resin components that were used on the sternantenna is the antenna base and the insulator.
The tank doesn't come with the copula mounted AA MG, or the MG mount. For this tank I picked up the Armorpax white metal MG mount. The mount is excellent and was moded to have the gun and mount pivot. For the Gun I will be using the new generation 21st Century MG34, but I'll have more info on that later.
After these parts were added I took the tank out for a joyride.
I was also able to post a quick video up on youtube
The last thing that needs to be added to the tank is the MG34, and the MG34 ammo bag.
Luca Fossa
Post by Luca Fossa »
Hi John
Excellent work and beautiful painting job and weathering, i like it.
Just let me tell the number on the turret, altough perfectly realized, is quite strange, it means the 6th tank of the 6th battailon, 3th company, a bit unusual to be a "command" tank .
Luca
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi John,
Wow very, very nice!
You are a skilled model builder and painter, love the paint job on the tools and replace the white metal handles was a good move, well done I am impressed.
How do you create the worn out paint/metal surface? Drybrushing or something else? Please tell, looks fantastic.
One minor thing...the jack is a 10T and KT had 20T.
http://www.panzerbasics.com/index_files ... t/jack.htm
Today only Steve makes a decent 20T jack and I have often wonder why no one else has bother to make one in white metal/resin as all information about it is there on the Panzer Basics website.
I mean with all those Panthers, Tiger I and KT out there it must be a market for them...hint, hint :wink:
Look forward to see the MG34 issue, I assume you will make the correct MG34T and not a standard MG34?
It´s all in the details!
Hi John
Thanks for sharing this excellent build with detailed photos along the way. As always, I am amazed at your speed of each project you do, the number of parts you make and the end result. The finished Tiger II looks great and the scenery you have photographed it in could not be more perfect for that tank. :D
Awesome video. Would love to see yours and Simon's in column formation on that video. That would be great!
Thanks again
Has liked: 129 times
Been liked: 773 times
John,
Absolutely stunning job. I have to agree with the others, the snow setting is awesome for this model. The details you have added are a great example of what can be done to the stock model. One of the best ambush paint jobs I've seen. Your build is a great reference for all KT owners.
Another excellent addition to your incredible collection of vehicles,
Kind regards, Bob
martin pitcairn
Has liked: 781 times
Been liked: 8 times
Post by martin pitcairn »
John,
what a fantastic job you have made of this tank. It has been a real joy to watch this build, some of your work has been the best i have seen, the other thing with this build has been is a great show case of what can be done with the basic kit and the supplied parts. i realy want to thank you for the step by step photo's and descriptions of what you have done. you should be realy proud of what you have built!
Antony Rowley
Location: Back to Wirral home of the brave or not so brave, England
Post by Antony Rowley »
Luca Fossa wrote:Hi John
Luca
It must be just made up (To confuse the enemy) as Tiger Battalions only had 14 tanks per company and only 3 companies plus 3 command tanks - 45 tanks.
Anyway, your Tiger II looks stunning, one of the best so far. Well done.
BTW Armorpax do a great MG34T too but I'm sure you knew that anyway.
peter karlsson
Post by peter karlsson »
hi john!!!
REALY AMAZING WORK ON THAT KT :shock: :shock:
good insperation source for my own kt build in the future :D
thanks again john for a wonderfull time to follow your build :D
kind regards peter(peppe)
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
Hi John.
Its been a pleasure watching your build and the completed tank is the best KT i have seen.
Well done.
regards
Been liked: 1644 times
thats a lot of effort standing there john, it looks good, great use of the standard parts, amazing how quick you constructed the kit, no easy task! regards simon manning.
Per Sonnervik
Been liked: 1 time
Post by Per Sonnervik »
Hi John,
Nice build and paint job indeed. I wonder one thing; did you set the torsion bars according to the instructions regarding the angle?
I think the model needs to be lowered quite a lot to get the look of the real thing, see here;
compare your model to the real thing;
/Per Sonnervik
John Grima
Thanks everyone, as for the numbers the numbers are not based on an actual vehicle. The numbers represent that the tank is my 3rd armortek model, and the 66 is the armortek production number.
As for the tank's height I followed the armortek instructions very closely. If you look at your posted image you will see that the sprocket and the wheel hubs line up very closely to my model. What you see differently in the images is the idler position. The idler is in its current position because of the track tension that works best for me. When building the tank I first had the idler at the location it is in the real image and I was not pleased with the tank's performance.
I finished the tank over the weekend, but I have yet to have ample weather to take some decent out door images :x . Hopefully I will be able to take some out door shots by the end of the week.
John Grima
Kent Wiik wrote:Hi John,
Kent, Thanks for the heads up on the jack. I just might take you up on your hint :wink:
As for the scratch steel weathering I use simple old school silver paint dry brushing.
For this tank I will use the standard MG34, As I have seen it used in an image, plus the MG34 is such an elegant and classy weapon that looks well for this tank.
Thanks guys, The tank's MG34 and MG34 ammo bag have been painted and have been added to the model. The tank is now 100% complete!!!!
I have also added the rest of the resin king tiger parts to the product line http://eastcoastarmory.com/germanparts.htm
For the tank's MG34 I used the new tooling 21C MG34 set that was released a number of years ago. The gun itself is nicely detailed, and is nice out of the box.
To improve the gun I eliminated the seam running down the barrel and gave the gun a nice repaint and weathering.
The gun was an easy fit to the armorpax gun mount.
I took advantage of the moderately warm temperature and took some out door shots of the finished King tiger and my newly finished DML schwimmwagen.
In the rare case the tank ever breaks or gets bogged down I can always tow it with this back up plan. It's not an M88, but it will do the job .
Now that the tank is complete I will be creating the gallery web page. Once complete I will be able to start on my next tank!
