Mr Dawe's Centurion.
- Has liked: 2259 times
- Been liked: 7147 times
Re: Mr Dawe's Centurion.
Just lots of machining photos I'm afraid.
- Has liked: 597 times
- Been liked: 142 times
Outstanding work Phil,
As always, thanks for taking the time to show and explain your work in progress. Watching that huge lump of aluminum gradually being transformed into the searchlight has been……illuminating?
Kevin
Kevin
Thanks Kevin, the body is in fact a little too long right now but I'm reluctant to trim it back untill we are certain as to the thickness of the glass lens that we are going to use.
There's still away to go yet.
- Has liked: 551 times
- Been liked: 409 times
Thanks Oliver you make me blush lol. We have now decided on 1 mm lens glass so the main body has now been irreparably sliced.
- A searchlight with a Centurion bolted to it!
- 9953b9db95b8760aa7eca00c8cb0fdd0.jpg (52.71 KiB) Viewed 1047 times
The searchlight detail starts now.
- Has liked: 726 times
- Been liked: 1667 times
Hi Phil
That is a brilliant bit of machining on the searchlight. Top notch.
Gary
Gary
More watch making but we are getting there, we are referring to the piece as " the 1K searchlight" and that's not a reference to weight!
- Has liked: 738 times
- Been liked: 61 times
Such a pleasure to see the skill and craftsmanship you bring to your builds, Phil. Thank you for sharing your work, a true Masters Class on so many levels.
This level of detail is ridiculous.
After much farting around.....we have light. As I can't be bothered wrestling with the predictive text tonight use your imagination
- Has liked: 762 times
- Been liked: 1739 times
I'm a bit lost Phil.
What's being used in the searchlight? LED or bulb?
That bulb looks the part Phil. It would be a shame to put an IR filter in front of it
