Cheers, Bob, Iacopo, good to hear from you.
Preparation includes this method for bending a small flange, where there isn't enough shoulder to use the brake press:
For tackling a complicated assembly, it's helpful to have a range of ways of attacking each stage. This is my array of soldering options:
- for seams, a torch, silver solder and a liquid flux to run between the surfaces. I tend not to sweat the parts because any build up will make accurate assembly and work holding more difficult. The resistance soldering probe is also useful for subsequent seams where you want to localise the heat in order not to undo previous work.
- for adding details, either the gas soldering iron or the resistance soldering callipers and low(er) temp solder, with a paste flux.
- I've successfully used the aluminium solder in the third photo but only with a torch capable of 700 deg C.
Key to successful soldering is clean, abraded surfaces, sufficient heat, flux and above all, solid work holding. The steel sheet and earth magnets are fine for lighter components, probably with a variety of clamps but I find best of all is to use a hulking great chunk of steel bar. This can be arranged to apply a downward force where it's needed and also act as a heat sink to localise heating to where it's needed. If a seam needs adjusting, I'll use the steel bar with a quick application of torch flame. The Proxxon torch is brilliant because the flame is very controllable and pin-point accurate. It runs on lighter fluid.
First part of the assembly done for one side:
Interesting to hear of other approaches, there's a lot of expertise to amongst us to add to the corporate knowledge (plug!)
