- Has liked: 2267 times
- Been liked: 7152 times
They are great little masterpieces for sure and a must for the serious builder, I would expect a lot of orders for those Dave! On that note Dave I need to order another four of the water slide transfers please as I had a reaction with the clear lacquer which bubbled the material but sometimes even us hardened builders have problems! so a tip don't use automotive lacquer to seal!
- Has liked: 116 times
- Been liked: 1106 times
Hi Phil,
No problem, i'll sort some out and post. I use Vallejo Metal varnish for the base and top coat on the extinguishers and as a base coat on the drums. Then use Vallejo Matt varnish for top coat on the drums, or any matt item.
Dave
Dave
www.armorpax.net
Cheers mate
More done and now planning the next opening to detail.
- Another addition that I am now planning is this little lot. I will need another seat from Dave which will need modifying some what. I wonder if Dave has something a bit closer from another kit upgrade?
- IMGP5662.jpg (78.45 KiB) Viewed 1143 times
Hi Phil,
Quad seat pads or Dingo is about it unless I make a new seat pad. Would need a couple more pics and enough interest though.
Dave
Dave
www.armorpax.net
Well fellow builders can express an interest right here ! What's the minimum number of orders to make it viable?
2,500
www.armorpax.net
Lol do you have any master cylinders Dave, I need two for front left of the seat?
- Been liked: 1798 times
Keep on fettling Phil, Dave's not going to make it easy for you.
Super original stuff going on here.
I was thinking "Pop up Pirate" type animated Driver head like this idiot, push down the head and torso, close the hatch.
But I'm half and half on the detail thing now.
The drivers seat was the only decent position in the tank I could get comfy. Everywhere else just try's to maim you or remove a limb. Tripping hazards everywhere and the chance of ruddy great green lump pulverizing your body into the back of the turret too.
Otherwise all good.
This 5P had a green seat.
Otherwise all good.
- Richard Goodwin
- Has liked: 294 times
- Been liked: 291 times
That drivers cab is extreme; nice one Phil!
On a separate note, could you tell me what is the maximum height you can have at the position where you currently have the batteries located?
VMT
VMT
I will check the clearance Richard but it may be more like the available depth down from turret ring, the protruding elevation mech is the ptoblem, also remember the gun was not an artillery piece so keep the barrel low!
- andymusgrove
- Has liked: 194 times
- Been liked: 89 times
I'm in the middle of having a couple of days off ,so here's a very nice diagram that I found of the drivers compartment for all those who would like to reproduce it.
I'm back on the case, the half battery boxes .
- Has liked: 598 times
- Been liked: 145 times
