Armorteks next model
- Has liked: 1038 times
- Has liked: 41 times
- Been liked: 29 times
Re: Armorteks next model
Hello Adrian,Adrian Harris wrote: ↑Sun Dec 27, 2020 4:37 pm> DEMAG D7 Sd.Kfz 10
That shouldn't be too hard as I believe it uses the same chassis and running gear as the Sd.Kfz 251.
Personally, I'd love a 250, so I can make Rommel's 250/3 'Grief' command base or the 250/9 with the 222 turret on top.
for me it is hard to build this for myself without maschines or something to made the parts you need.
I stand with a file and a drill on the front. ( laugh ) So it would be nice Armortek can do this for me.
The Sdk.Kfz 250 uses some Parts like the Sd.Kfz 10 but the drive is a little bit shorter. They removed one Wheel.
And it is not the same like the 251, it smaller and shorter than that from the 10 .
But i think for an professional Modeller it is no Problem to cut the chassis from the 10 and make the drive a little bit shorter for an 250.
Regards Timo
Manchmal muss man auch gegen den Strom schwimmen!
- Has liked: 242 times
- Been liked: 217 times
It doesn't have to be a MKIII Centurion...I can build what I want to build with a reissue of the existing Centurion...Unless we could get a re-release of the Comet?
So that's three for a Centurion then?
Alex
P.S Sorry Chris
Alex
P.S Sorry Chris
Quicquid agas age
- Has liked: 99 times
- Been liked: 446 times
If Armortek makes a run of these, I'll never ask for anything else ever again...
RPR
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
- Been liked: 3697 times
Our 2021 survey will be going out shortly.
Whilst we are limited in the number of choices we can put in the survey, if you want your suggestion included (no guarantees) then let us know in the comments below. You only have a few hours
- Has liked: 2519 times
- Been liked: 444 times
- Been liked: 741 times
- Has liked: 257 times
- Been liked: 147 times
- Charles A Stewart
- Has liked: 510 times
- Been liked: 928 times
With you John all the way, Armotek could certainly develop the variants as they go, surely.
Cheers Charles
Cheers Charles
Or this nice cabrio
Please.
Please.
Regards Timo
- Has liked: 7 times
- Been liked: 46 times
- Been liked: 1839 times
MkIX Chieftain turret upgrade kit.
with a free Chieftain ARRV
Failing that F101 Scorpion
(What great name for an AFV)
