Page 35 of 95
Posted: Thu Feb 06, 2020 4:26 pm
by Phil Woollard
More wiring and the Armorpax parts arrived. 8)
Posted: Thu Feb 06, 2020 5:55 pm
by Phil Woollard
Would anyone have any reference photos of the drivers compartment they could share please, I would be so grateful 8)
I have these two be!ow.
Posted: Fri Feb 07, 2020 8:08 am
by andymusgrove
Phill
Found this for now ill have a look see what else i can find
Andy
Posted: Fri Feb 07, 2020 8:28 am
by andymusgrove
Another one
Posted: Fri Feb 07, 2020 11:52 am
by Phil Woollard
Excellent Andy, boy for a big vehicle there's not a lot of room in there!
Posted: Fri Feb 07, 2020 11:59 am
by andymusgrove
Welcome - i'm sure ive got more just cant find them..
You would be surprised actually there is a fair amount of room, I'm 6'4'' and happliy drove even closed down was comfortable = although my main role was gunner or Loader
Posted: Fri Feb 07, 2020 12:05 pm
by Phil Woollard
You big bugger you! If you can find the others that would be Great as I have had the go ahead to build the drivers compartment, should be challenging 8)
Posted: Sat Feb 08, 2020 12:56 pm
by Phil Woollard
I've made a start on the drivers compartment. 8)
Posted: Sat Feb 08, 2020 2:23 pm
by Kevin Hunter
Outstanding Phil. I’m always amazed how many forum members can take a photo and then recreate the detail in miniature. You make it look so easy. A nice touch to an already impressive build.
Keep it up
Kevin
Posted: Sat Feb 08, 2020 2:42 pm
by Stephen White
Great job there Phil, you've done just enough to make it convincing but not wasted time on things which can't be seen.
Posted: Sat Feb 08, 2020 4:23 pm
by Phil Woollard
Thanks guys, I think it needs the battery boxes down both sides, well half boxes anyway or I won't be able to slide the assembly in 8)
Posted: Sun Feb 09, 2020 1:00 pm
by Phil Woollard
The fiddly fire extinguishers, and planning the battery boxes for the drivers compartment. 8)
Posted: Sun Feb 09, 2020 6:03 pm
by Dave Dibb (Armorpax)
Don't want to make it too easy for you Phil :-)
With the end cup and webbing strap there was no easy way to make them unless I did them solid with the detail moulded in. Problem with that was the excellent artwork by Stephen would have had to be cut into bits and fitted round the clip etc.
Dave
Posted: Sun Feb 09, 2020 6:14 pm
by Richard Goodwin
They do look really good though!!
Posted: Sun Feb 09, 2020 6:34 pm
by Stephen White
Fiddly? You had the easy bit. Look good though, Dave's done a great job on them. There are some good, innovative threads on here at the moment. Makes a change from the same old......
