- Has liked: 2267 times
- Been liked: 7152 times
More wiring and the Armorpax parts arrived.
Would anyone have any reference photos of the drivers compartment they could share please, I would be so grateful
I have these two be!ow.
- andymusgrove
- Has liked: 194 times
- Been liked: 89 times
Phill
Found this for now ill have a look see what else i can find
Andy
Andy
- Drivers Seat.jpg (59.77 KiB) Viewed 928 times
- andymusgrove
Another one
- Chieftain Drivers Cab.jpg (93.33 KiB) Viewed 924 times
Excellent Andy, boy for a big vehicle there's not a lot of room in there!
- andymusgrove
Welcome - i'm sure ive got more just cant find them..
You would be surprised actually there is a fair amount of room, I'm 6'4'' and happliy drove even closed down was comfortable = although my main role was gunner or Loader
You big bugger you! If you can find the others that would be Great as I have had the go ahead to build the drivers compartment, should be challenging
I've made a start on the drivers compartment.
- Has liked: 598 times
- Been liked: 145 times
Outstanding Phil. I’m always amazed how many forum members can take a photo and then recreate the detail in miniature. You make it look so easy. A nice touch to an already impressive build.
Keep it up
Kevin
Keep it up
Kevin
- Has liked: 1024 times
- Been liked: 2094 times
Great job there Phil, you've done just enough to make it convincing but not wasted time on things which can't be seen.
Thanks guys, I think it needs the battery boxes down both sides, well half boxes anyway or I won't be able to slide the assembly in
The fiddly fire extinguishers, and planning the battery boxes for the drivers compartment.
- Has liked: 116 times
- Been liked: 1106 times
Don't want to make it too easy for you Phil
With the end cup and webbing strap there was no easy way to make them unless I did them solid with the detail moulded in. Problem with that was the excellent artwork by Stephen would have had to be cut into bits and fitted round the clip etc.
Dave
Dave
www.armorpax.net
- Richard Goodwin
- Has liked: 294 times
- Been liked: 291 times
Fiddly? You had the easy bit. Look good though, Dave's done a great job on them. There are some good, innovative threads on here at the moment. Makes a change from the same old......
