Pz III New Build
- Been liked: 68 times
Hi Stephen.
Brilliant I made my own bin for my early Tiger so I know how much work you have done...the wooden rubbing strips look great too.
I have spoken to Steve in the past about his brilliant clasps...don't know how he puts them together I got some in kit form and they are still the same way I just gave up ha ha.
Well done again.
Cheers Paul
Well done again.
Cheers Paul
01524 720977
01524 720977
- Been liked: 14 times
- Has liked: 1024 times
- Been liked: 2094 times
Colour and weathering begins
Fabrice, yes, anything to save the moment when I turn to the blowtorch, high risk of seeing the whole thing self destruct......
On with the finish coat. First the RAL 8020, painted to give some variation of light and shade:
Pistol port with cast numbers added:
Next, the RAL 7027 and then some Promodeller washes, applied wet and then, when dry, wiped away:
Next some pigments, this one is Promodeller sand and it gets the North African red dust on. I've used MIG Pigment Fixer and here, it's not quite dry:
Hi Stephen.
Just keeps getting better, still waiting hence no pic
Cheers Paul
Cheers Paul
01524 720977
01524 720977
Side Hatches
The last major components, the side hatches. Removed the welds from the Armorpax parts:
Test fit showed that some material needed to be milled from the mountings to get the hinges into the right position to allow the doors to open and shut:
Made up the hinge pins from brass to include the boss at the top:
Milled out the apertures for the vision blocks and small ports which will be working:
Side Hatches
More work on the side hatches.
Milled out the interior of the Armorpax vision ports. I'll use some water clear resin to cast the optics:
Started the pistol ports which are missing in the kit:
These inserts represent the mounting plate on the inside:
A test fit:
Construction of the actuating lever:
A test fit:
Stephen.
When you have finished this model you are going to end up getting an offer you can't refuse from a museum and your panzer three will end up in a glass case for posterity
Absolutely top notch it really is well done again.
Cheers Paul
Cheers Paul
01524 720977
01524 720977
Hi Stephen,
Great details on your Panzer III, especially following your recent work on the turret side doors. I had a go myself making the inside details on the doors. If you want to see any of my efforts on the Panzer III, then send me an email, my contact email address is as follows:
artmaniastudio3@googlemail.com
Ian
from Glasgow, Scotland.
Ian
- Has liked: 5 times
- Been liked: 669 times
More work on the pistol ports
John - don't know, never used water clear resin before. Having read the tech notes, getting the temperature and mix right seems important. I'll let you know. I will probably try pouring direct.
More work on the pistol ports. Completed the actuating levers:
Fabricated the bracket which holds the port shut:
Port open and shut:
Making these parts suggests how over-engineered the earlier panzers were. The pistol port is a door in a door - crazy. I've never seen a photo with one open or seen any reference to them being used. Mind you, the Centurions in Korea could have done with them (hint Mark!) Makes for a satisfying build though - always more bits to knock out.
Port open and shut:
Stephen, super job!
Pistol ports anticipated tactical failure. QED As tactics improved they were dropped from newer designs.
Blindly shooting at infantry on, or close to, the vehicle repesents a last ditch defence of a high value target that has got itself too far ahead or separated from a) the infantry who should be protecting it or b) from other tanks who could hose off the close-assault infantry teams with co-axial MG fire. (As the Cents did in Korea!)
Armoured glass has a greenish tinge due to its thickness and composition. Will you add this with a wash of paint or by tinting the resin mix? You could also use green film of the type use as lighting gels for theatrical lighting. Very stable and good range of colours.
Cheers, Fabrice
Cheers, Fabrice
- Been liked: 177 times
HA HA!
I love it! It just keeps getting better and better with each new post(and that's saying something). Incredible. Just incredible.
To fabrice's point, you can buy greenish tinted plex here in the states that is supposed to represent real glass. May not have quite the amount that Fabrice is talking about but it does look like glass.
best regards
best regards
Cast Marks
John
Sad to say they're the correct casting numbers:
Obviously too much time on my hands......
