Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Lots done and lots to do.
A bit of chain drilling needed to profile the hatch pad cores
I'm using the mill to shape the hatch pad cores
Roughing out
Roughing out
Starting to take shape
Reducing the thickness
All ready for covering
Black vinyl
Black vinyl
Carpet adhesive is convenient
I can't fix the pads just yet
The tan leather strap needs painting
I'm happy with the look albeit far to pristine
I've joined the weather strip , this will be hidden later
Relief for this side only as the turret inner surface is in the way
That's the correct height for the weather strip
Nearly there with the loaders hatch and associated.
Milling all those angled slots
I think these angled slots are to increase the weld surface area  ?
The com's plug socket is an important detail
Good old hacksaw
Good old hacksaw
Roughing down
Roughing down
That's the first time I've used this feature on this mill
You can probably see that the fixing tapped holes are drilled all the way through, it's easier this way as you don't have the problem of bottoming out the tiny m2 tap, just fill the hole latter.
Roughed out the two remaining armour pieces
It's easier to chamfer these short pieces this way round
Nearly done in this area, finishing off the last two armour pieces then milliput welds and some casting numbers tomorrow
And for the patient purists, the loaders hatch but for top coat is finished.
Does anyone know of an stl file of the Morris donkey engine, any scale is ok as I can resize. Even a very similar engine would be ok as I can modify to suit?
OIP (12).jpeg (43.75 KiB) Viewed 1202 times
Only one fixing necessary to hold these smaller armour blocks in place, thin cyno also helps secure the whole thing.
3 mm casting letters and numbers
Milliput, lots of fiddly weld beads
I'm looking forward to applying the NATO green
My favorite aspect of this piece......it now fits and so clears the cupola
Online
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Coming along nicely Mr W! :)
More of those armour pieces
This block supports the scissor sight
Roughing out
Roughing out
These angles were tricky
Lots of angles
Lots of angles
This tilting feature is very useful
The final flat for this piece
I'm getting lazy using this mill to square pieces off, I may forget how to do it by hand
Steve Lewington
Has liked: 8466 times
Been liked: 277 times
Post by Steve Lewington »
Outstanding work phil always a pleasure to see.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Kevin Hunter
Has liked: 597 times
Been liked: 142 times
Post by Kevin Hunter »
Just fantastic.
I look forward to every instalment.
Here's another for you Kevin.
Have no idea what this piece is for?
This piece has an m3 right through it
Lots of m2 fixings from below
Milliput weld beads
Milliput weld beads
There that strange mount thingy is done
Umm?
Umm?
Getting rid of the old paint then this base will be a good start
Extra fixing holes required
I think I have enough material to make The inner sight casting
Michael Cecil
Has liked: 73 times
Been liked: 109 times
Post by Michael Cecil »
That 'strange mounty thing' is the coolant header tank and filling point for the sight elevation control arm cooling system (or whatever its correct nomenclature is!). The elevation bracket pivots from the turret roof and is connected to the armament by a link bar. The link bar is a tube which is connected via piping to the coolant reservoir. It is to keep expansion/contraction of the link rod to a minimum due to variations in temperature and hence, minimise alterations to the armament-range gear relationship. Only applicable to Centurion :D tanks equipped with the RG.
Mike
Thanks Michael, getting along with the gunners scope.
Off we go with roughing down
Marking out the armoured lump ready for milling
I cleaned the mill over the weekend
Checking the fits
Checking the fits
Awkward piece to work this
As I'm making the scope armour from a number of parts I can mill right through this important piece
I like milling the scope material
The lens is now bonded in so I can machine down as a unit
Squaring off the scope roof
Reducing the scope lid
And now to machine down
Lowering the unit until it's the right height, most of this will never be seen as it's hidden under the weather cover
Lots done to the sight.
I'm going to use the bond and bolt method as it's very quick and very accurate
See if you can work out how I do it?
M2 counter sink are very strong in stainless
All bolted together
All bolted together
Cutting out the cover sides
All marked out
All marked out
Sketchy but very quick
Filing and fitting
Filing and fitting
Tricky little piece coming up
Soft solder is fine for these parts
I'm getting very brave with the mill
I shall be repositioning and reducing the those fixings along the rear . And now onto the top which will be challenging no doubt
A bit more done.
I need to increase the side angle
Cutting out the cover side pieces
This spare steel sheet came from the bazooka plate of a 1/4 scale Panther
I've now increased the side angle of the periscope enclosure
Front armour piece
Front armour piece
Lots more to do
Lots more to do
Online
Phil Dawe
Post by Phil Dawe »
So how does the bond and bolt method work Phil?
Chang
Has liked: 15804 times
Been liked: 424 times
Post by Chang »
...1/4 scale Panther...
Sounds interesting. :-D
Email me Chang ptwoollard64@hotmail.com
Moving forward with the sight.
Just had to get some paint on the work to check the finish
The wiper motor enclosure
For the boss, how the bond and bolt method can speed up the job
Mark out and drill the fixing hole positions in the plate with your tapping size drill bit.
Bond your part exactly where you want it
Use the tapping size drill bit as a guide for an accurate hole, open up the plate holes with a clearance drill bit before you fix.
Snap the bonded part off the work,  then tap away, clean away the hard cyno from both surfaces.
Bobs your uncle a perfectly placed and fixed part
Temporary mount
Temporary mount
There's a long way to go yet.
