Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Lots more done and lots more underway.
Squaring brackets required for the rear reflectors
I just as well make and fit the mud flap retaining strip while I'm here.
I'm not really keen on using brass but needs must, the reason.......when it "chips" it looks too shiny unlike steel.
Primmer
Primmer
I know I keep saying it but 12ba is plenty small enough to work with
All ready for the mud flaps, if we fit them that is
Best get this set out, bent up, drilled and tapped
Working on the mantlet and the turret mantlet mount
The first set of steel strips made and drilled
Ummm
Ummm
These are the profiles I'm after
I see some builders have glossed over this work either not addressing it or not showing their workings.
Lots of filler required here , more than one coat needed until it's right,
Some rubbing down and another layer applied until it's right
A good finger drilling afternoon's work
That 1/35 turret is a God send
I managed to find a supplier of the strip steel on the interweb which was most convenient
Nice reference photo
Filing a flat for the strip steel to sit on
The steel bends beautifully when cherry red
Heat up bend and fit
Following the lines
Following the lines
Drill, peg and drill again
Not to much filler needed in this area
All ready for another stab tomorrow
Finished the weather cover strip for now, the strikes are now becoming a pain in the arse as we are waiting for parts and tools to arrive.
The mantlet work looks ok to me
I did start by using brass for the IR lamp bracket but it warped as usual
Ready for the IR  lamp bracket
I'm always silver soldering something
I'm scaling from the 1/35 model and it requires only minor tweaks
Cutting the IR lamp bracket support end
It's a big lump of steel
There's lots of milling required with this piece, I did notice that the IR lamp arm is tapered in depth being shorter on the right than the left ( as you look at the vehicle from the front) this I believe would have shed any rain water away from the canvas opening.
Working on the IR lamp bracket and associated, I just as well get this all built while I'm here
Set up if a bit sketch
Milling the second taper
Milling the squares
Milling the squares
Adding extra steel to get the correct size at the lamp end
Milling the mounting block
Mounting block in place
Cutting out the various bracket parts of which there are many
The lower bracket sits on top of the mantlet arm
This is where the lamp bracket sits
I shall cut a 2mm slot to take the upright bracket prior to silver soldering, I can then mill the bracket profile
That IR lamp bracket is nearly done.
Milling out the gusset footprint
All silver soldered so it's very strong indeed, 72 tons/square inch strong!
There's a surprising amount of detail in this piece
The lamp housing spigot thing
Swivel bolt slots x2
A coat of grey primer will show up any imperfections
Those set bolts are used to line up the lamp with the weapons
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
It is always a pleasure to see the rapid progress.
The weather cover strip is superbly done and well worth the effort.
It's Grim Up North
Thanks Oliver, I have now finished the IR lamp bracket and I've ordered the aluminum bar so I can turn the lamp it's self, it is just about as big as I can handle on my lathe .
The tiny hinge parts turned ready for a little milling slot to hold the m3 thread whilst I solder it
Very tricky silver soldering these tiny parts
Hinge bolt in place and tight ready for the back piece
22 gauge for the back of the hinge, the four fingers you can see sticking up are ready to be bent around the hinge bolts pivots .
Difficult to see the work piece
22 gauge can be simply bent around the hinge bolts once bolted in situ, this forms the female part of the hinge
Turning the bolt end stops
The captive hinge bolts have been 100% successful
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Those bolts are superb Phil, well worth the time and effort!
David Battson
Has liked: 108 times
Been liked: 232 times
Post by David Battson »
Hi Phil,
Lovely fabrication work on the bracket. It's great to see these parts being made up in steel and operational as well.
The aluminum for the IR lamp body turned up today, who needs the Royal Mail.
As I said it's about as much as my lathe can handle.
First job is to turn the end sections that hold the glass.
Once bored out with a step to hold the glass on the ID and the outer ribs formed it can be parted off
Kevin Hunter
Has liked: 597 times
Been liked: 142 times
Post by Kevin Hunter »
Have been looking forward to seeing how you planned on tackling the IR spotlight. Thought you might go the 3d printed route, a la Stephen White.
Watching with great interest.
Kevin
Kevin I can't believe how big the lamp is, I'm not keen on the thing myself.
Whilst we are waiting for dimensional information from the tank museum regarding the IR lamp sizes I shall get on with the loaders hatch work.
This arrived recently, how can the Chinese do it so cheaply , and it's not half bad!
I'm not really looking forward to this work.
Remember the rear hatch will in no way open correctly as it crashes into the cupola!
Patterns
Patterns
The most convenient way to cut the parts from the plate
Tidying the roughing
Still roughing at this stage but squaring off at the same time
Tongues
Tongues
A tip, you can use a centre drill as a milling cutter for those tiny slots that tend to break the standard 2.5mm slot drills
Milling the tongues down untill the fit is perfect
Just machining really.
.....and a bit of hand work to
The kit hinges And surrounding areas need to be replaced in a big way as you will see in later posts
Squaring off
Squaring off
Using a surface plate and scribing block to mark out
All marked out
All marked out
Four of everything
Four of everything
I did consider using those white metal male hinge pieces but they are not quite big enough
Squaring off
Squaring off
Hand saw again
Hand saw again
Roughing out nearly done
A nice tight fit ready for drilling the pin holes
Lowering required now
