Panther G 2022 #15 Build
Malcolm.Plumb
Has liked: 460 times
Been liked: 952 times
Re: Panther G 2022 #15 Build
Post by Malcolm.Plumb »
Quite a productive day off today with the hull base primer coat done, interior painted and the basic hull assembled.
Pretty pleased so far :D
2022 Panther G #15
Malcolm.Plumb
Getting the deck parts more or less aligned so I can tighten up all the hull fixing bolts.
Somewhere near I think without any removal of material needed.
2022 Panther G #15
Gary Rafferty
Has liked: 252 times
Been liked: 442 times
Post by Gary Rafferty »
Malcolm.Plumb wrote:
Sat Jun 03, 2023 7:37 am
Hi Malcolm
Nice job,Looks cracking I'm building the rear deck today to check for fit.
Gary
Malcolm.Plumb
It is so easy to slightly over tighten the fixings on the top side hull sections and close up the gaps on the top deck too much.
I’ve been using plastic card as a gauge to try to get the gaps as even as possible.
2022 Panther G #15
Malcolm.Plumb
Bump stops started and a few parts I wanted to paint before fitting to the hull later.
2022 Panther G #15
Malcolm.Plumb
Still working on the main hull trying to get it ready for the second primer colour and lower hull top colour.
Main fixing screw holes are now covered up and on to the weld beads next.
Best have a practice somewhere first I think :wink:
2022 Panther G #15
Malcolm.Plumb
First attempt at weld beads on the main hull with just a few remaining to do.
This is about 5 hours of work today :shock:
Many thanks to Vince for the heads up on the extrusion tool - very very handy indeed :D
2022 Panther G #15
Gary Rafferty
Sun Jun 11, 2023 3:53 pm
Hi Malcolm
Very nice looking weld beads, were did you get that extrusion tool it will save a lot of effort
Gary
Malcolm.Plumb
Hi Gary
Off Amazon if I remember correctly.
A really useful and not too expensive tool giving such a variation of even bead diameters to work with.
The very smallest ones I think you would maybe have trouble with without it.
You just have to make sure to get every thing you think you will need through the device early on and get it cleaned up. Not a problem though.
2022 Panther G #15
Malcolm.Plumb
Just a little bit done over the weekend.
Basically the hull has been flipped over and more weld beads added.
The machine gun ball mount to be added next and given the same treatment.
2022 Panther G #15
Charles A Stewart
Has liked: 514 times
Been liked: 933 times
Post by Charles A Stewart »
Hi Malcolm.
Are going for the access hatches as you are inverted?
Cheers Charles
Malcolm.Plumb
No not this time Charles.
2022 Panther G #15
Malcolm.Plumb
Very busy at work so only a little bit done this evening.
Done but going to be covered in Zimmerit anyway.
2022 Panther G #15
Malcolm.Plumb
Quite a few days later and the hull is now ready for its all over Red oxide coat and base colour painting on the floor and hull sides.
Quite a tedious and lengthy job though to fully mask of the cream painted interior to stop any red getting in to it :roll:
Lets see if we get some good weather over the weekend.
2022 Panther G #15
Malcolm.Plumb
A busy day at work but some nice weather this evening so managed to get a bit of painting done.
A bit more to do to this tomorrow hopefully.
2022 Panther G #15
