Yves sdkfz 251 update
Forum for discussion relating to the Sdkfz 251
Uwe Gerstenmayer
Been liked: 72 times
Re: Yves sdkfz 251 update
Post by Uwe Gerstenmayer »
Hello Yves,
some nice info and pics , small but still good enough to get an idea, is on Piet van Hees website about the 251 with a PAK40.
When you open the site scroll down a bit and have a look at the "period pictures".
https://www.pietvanhees.nl/251/04-251-22.htm
Hope it's working and helpful
cheers Uwe :wink:
1:16 Models: Kingtiger
yves mouton
Been liked: 741 times
Post by yves mouton »
Thanks Uwe
I found 3 pictures with a layout of the inside.
Best regards Yves
yves mouton
Hello,
Working on the pak 40, was a little bit cutting to do on the shield,
also cut a part out of the roof.
Best regards Yves
Has liked: 162 times
Been liked: 849 times
Yves that's going to be cool setup. From the photos in the link it looks like the gun shield was also cut shorter, it doesn't extend below the base of the gun. Hoping to save you cutting away too much of the sides? Perhaps you just have the side of fighting cpt removed temporary. Looking good!
yves mouton
Hello Robert,
No i didnt not cut the side to mutch, i just cut a little to fit between the the side of the compartiment. The underside of the shield i did not cut for the moment. That i will do tomorrow.
Best egards Yves.
yves mouton
Hello Robert,
The top of the fighting cpt, can open with 2 servo''s when the pak is moving from left to the right.
Best regards Yves
yves mouton
Hello,
Today a free holiday so i workt on the interior of the 251.
I made a model in cadrboard first and than cut it out in alu.
Cut out the door of the ammo box
Made a box th hide the 2 servo's on the left side
Best regards Yves
Heiko Sattler
Been liked: 535 times
Post by Heiko Sattler »
wow nice i follow your work very closely i am very curious how much you detail and build up this combat room
yves mouton
Hello,
Thanks Heiko, about the interior it's not gonna be the same but i do my best :)
Today i made a bigger turning wheel for the volume.
Also made a cut in the floor to fit the power module.
The 3 boxes need some welding soon.
Best regards Yves
Tim Page
Has liked: 40 times
Been liked: 471 times
Post by Tim Page »
Nice, interesting build and subject Yves.
I thought that these were only built using the later ausf.D type of 251.
Have you found an example based on the ausf.C or is this a bit of modellers licence?
Looking forward to seeing the completed interior.
yves mouton
Hello Tim,
This is my own creation :D normaly there was no pak 40 on this model :D
Today i put some work on the interior ( decals ) not finisch yet but a start.
It was a difficult work the glue the small parts together.
I used plastic for the glass look and some rings from sanitair.
Still need to clean the edges with paint.
Best regards Yves
Tim Page
Has liked: 40 times
Post by Tim Page »
I really like what you have done so far Yves.
I am also working on a 251/1 ausf.C but mine will be completed as a troop carrier.
Good luck with your build.
yves mouton
Thanks Tim
Is your 251 build also to follow on the forum?
Best egards Yves
Tim Page
Has liked: 40 times
Post by Tim Page »
Hi Yves, Sorry, No.
I wont be able to post any updates here.
yves mouton
Hello,
Yesterday with help of Sven S program my graupner transmitter hott mz 24
everything works now, drive , steering , smoker , sound , recoil and flash
Now working on the servo's for the doors, side panels en the four visiers.
Best regards Yves
