Steen's StuG 3 build thread
Robert Tanzer
Has liked: 1122 times
Been liked: 990 times
Re: Steen's StuG 3 build thread
Post by Robert Tanzer »
Nice to follow your build Steen.
Great work you do.
What material are you using to make the weldlines?
Take care.
Robert
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Hi Robert
I am using this 2 component stuff
https://www.ebay.de/itm/Green-Stuff-36- ... 890.l49292
cheers
Steen
Steen Vøler
Has liked: 62 times
Dryfit of wheels and track.
cheers
Steen
Steen Vøler
Has liked: 62 times
Where on panzerteam.dk battlefield today for the annual Christmas party and took the opportunity to use the drill machine in our workshop to bore out the holes for the brass netting to be fixed with 3mm scale bolts.
A Merry Christmas to you all from Denmark :D
cheers
Steen
yves mouton
Been liked: 741 times
Post by yves mouton »
Nice black panzer cap in the background,
i have the same 8)
Best regards Yves
keithbraun
Has liked: 38 times
Been liked: 29 times
Post by keithbraun »
Hello Steen, I'm just reading through some of the Stug builds on here. Did you have any trouble with the recessed bearings on the idler wheel? I think it was 'Roy's Stug build' that mentioned it.
Steen Vøler
Has liked: 62 times
Hi Keith
It was only that one of the idler wheels had the 6 holes on the wrong side.
Was an easy fix. Just used the existing 6 holes as master and drilled through, made the 3mm thread and sealed the wrong 6 holes
The bearings did fit smoothly into the idler wheels and are loctited as per the instructions
cheers
Steen
Steen Vøler
Has liked: 62 times
Some more pictures
Made threads in the idler wheel and also on the 2 air intakes for the bolts to fix the brass wire mesh
The fluid in the white cup is 90% alcohol. A tip to do problem free threads is to dip the thread cutter in alcohol for a smooth threading. The alcohol smoothes the aluminium
cheers
Steen
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Nice work Steen, thanks for your tips, Mick.
Robert Tanzer
Steen Vøler wrote:
Sun Dec 20, 2020 11:00 am
Some more pictures
Here in Sweden we have this, and this alcohol make all cutting work in aluminium realy smooth.
Robert
Steen Vøler
Has liked: 62 times
Just some small details made
Drilled the 3mm holes out to 4mm and threaded both the parts for a firm fit and finished with threaded the castle nuts
cheers
Steen
Steen Vøler
Has liked: 62 times
Most of the stug loosely assembled to get a feeling of the soon finished model
Still need to adjust suspension
cheers
Steen
yves mouton
Hello Steen,
Do you have problems with the trackhorns fitting on the rubber tyres?
Because i see a few wheels that dont fit properly?
Best regards Yves
Steen Vøler
Has liked: 62 times
Hi Yves
No, There are no problems with the roadwheels. It's because the stug is blocked up, so the track is actually just lying on the surface with 2 extra track links installed. The roadwheels are not touching the track.
cheers
Steen
yves mouton
A ok
Regards Yves
