RCSparks Elefant Tank Build - This should be an awesome experience!
- Has liked: 1484 times
- Been liked: 1693 times
Re: RCSparks Elefant Tank Build - This should be an awesome experience!
When you play the main gun sound, there is a servo signal generated on "RC Connections" #2, which should go to the servo by the limit switches. No other connection is needed to the receiver as the Audio Module does all the syncing.
On older models, this servo pulled on the barrel to create the recoil movement. As guns have grown in size, this put too much strain on the servo, hence the spiral system now in use on the bigger models.
Once the Audio Module is powered up, the servo should go to the ready position. Then, when you play the main gun sound. the servo should run through a set arc and back to the ready position.
I'm afraid you're going to have to reset the limit switches, once you have the recoil operating from the Audio Module.
Last edited by Adrian Harris on Sun Dec 16, 2018 10:00 pm, edited 1 time in total.
- RCSparks
- Has liked: 38 times
- Been liked: 59 times
These instruction books are very important..
But you have to have a servo connected to the RX to get the input from the Transmitter to fire...
Thanks Adrian...
Thanks Adrian...
RC in the Mornin', RC in the Evenin'!
You're 95% the way there.
Once you get the servo moved from the RX to the Audio Module, you should only need to reset the limit switches, so the servo fires off the motor when you play the sound.
- RCSparks
OHHHHHHHH
So when I ply the sound, the gun is supposed to fire..
Im getting clearer now..
THANK YOU!!
THANK YOU!!
- RCSparks
Adrian, or Brian.. might you have the instructions on setting the limit switches? I did what Arian suggested..
When I start the tank, the servo is closed on the limit switch.. but after 10 seconds or so, the servo moves to the release position, and does not return. The gun just cycles, with no sound.. and the snail cam goes round and round.
Its like it needs to be reversed. Since its not in my RX.. im not sure how to reverse it
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
I don’t know if this helps. I haven’t set mine up yet.
- RCSparks
Adrian...
Brian....
I got it
Its firing perfectly now.. no reverse needed.. You guys have saved the day ! THANK YOU SO MUCH FOR YOUR SUPPORT! I am shouting you guys out in the next video for being Armortek Hero's
Brian....
I got it
- Brian Ostlind
Awesome brother! I’m happy to hear you got it sorted out. Have fun!
Glad you got it sorted.
Now the fun really begins
- RCSparks
THE FINAL VIDEO of my Series.. is ready for all of you NOW!
Thank you all for your support.. in getting this tank sorted and ready! Now, I just have to tighten up my tracks..
[youtube][/youtube]
[youtube][/youtube]
- Has liked: 107 times
- Been liked: 91 times
Sweet, I've been waiting for the next video!
- RCSparks
Happy Holidays Everyone!!
Quick question to all the builders out there .. I notice that my kit did not come supplied with a machine gun servo mount, light, or audio setup...
Is this a different option from Armortek? Anyone hooked their Elefant machine gun up?
Thanks!
Thanks!
- Brian Ostlind
You know you gotta paint it right!
- RCSparks
Brian, to be quiet honest this B.E.A.S.T can be painted anytime.. we can will enjoy it in stages.. BUT! I'm not all about the WW2 theme to be honest.. and personally, its not anything that I have any attachment to.. I just think that this is a super cool tank destroyer! What a great project to build with my friends. Silly as it may sound.. the TD is organically becoming what it is. Im just another artist letting the TD tell me what it wants to be..
Being a 10 year celebration project for our show on YouTube, we never did things "by the book".. and always do our best to think outside the box.. it's what we have been told made the show unique and unexpected, with a twist of inspiration for some. I am amazed jobs that the artists do on this forum, and I continue to learn from the posts here daily. The skill and talent is truly extraordinary.. but like every artist.. for the moment, I have a different vision.. A more modern, aggressive, and intimidating looking "muted" Policed State, style of machine. It will evolve and change with time.. like all projects do. The evolution...
- RCSparks
RCSparks wrote: ↑Mon Dec 24, 2018 9:33 pmHappy Holidays Everyone!!
Thanks!
Anyone help on this, or are we all focused on my paint now ? Heh
