SdKfz 251 build
Forum for discussion relating to the Sdkfz 251
michael hilton
Has liked: 1564 times
Been liked: 835 times
Re: SdKfz 251 build
Post by michael hilton »
Hello Dennis, thank you for the reply.....and yes, Eric does mention the 'handing' of the hinge brackets, I clearly missed this advice. Meanwhile, I am building the cab/engine compartment/rear body/rear doors as separate units.
I will fit an aluminium floor to the underside of the chassis. I sprayed the floor with primer then immediately knocked it off the table, guess which way down it on the floor it landed.....like a piece of bread and jam....Mick
Tom Wittstock
Been liked: 18 times
Re: SdKfz 251 build
Post by Tom Wittstock »
Hello Mick, did you make this floor? If so would you be so kind to offer the measurements when you get the time :D
michael hilton
Re: SdKfz 251 build
Hello Tom, the underside plate is aluminium sheet, 2mm thick, 175mm by 450mm. Measure your 251 to be sure.....I drilled and tapped into the chassis, five M3x6 hex head bolts each side. You could probably use smaller or less bolts as the floor does not support any other part. I purchased the aluminium as an pre-cut standard size from eBay.....Mick
Tom Wittstock
Re: SdKfz 251 build
Hello Mick, I'm working on building the sprocket. I'm working on getting the CM0217part along with using the two pin's (4x16). Any hints on making it go on as easy as possible? :shock:
Update, got them on but I have another question does part no.MM0219 have to move freely (Spin)? Some of mind do and some don't :?
michael hilton
Re: SdKfz 251 build
Hello Tom, all of the rollers CMO219s should move smoothly, just ease the holes in CMO217, you may find some 'burring' in the holes on the sprocket ring. I think I used a round file.
I also assembled the sprocket and the ran a drill bit very carefully down the sprocket ring where the pins are located, the 4x16 pin will then fit easily. Don't use an oversize drill though, just clean the hole and make sure all the parts line up. The pins need to be a good tight fit.
Most of my parts are built and awaiting paint....I still cannot decide on the final layout inside the 251. I would like to install a 'searchlight' if I could find kit or ready built searchlight model.....Mick
Has liked: 1024 times
Been liked: 2094 times
Re: SdKfz 251 build
Great progress Mick.
When you win the Lottery:
http://www.ebay.co.uk/itm/Toys-Model-WW ... 1552824801
Sorry!
Dennis Jones
Has liked: 10 times
Been liked: 223 times
Re: SdKfz 251 build
Post by Dennis Jones »
That's the model I picked up secondhand for about £30.
michael hilton
Re: SdKfz 251 build
Hello Dennis hello Stephen, thank you for your comments. I have a war time memory of 'searchlights'. I recall my auntie taking me to see a searchlight in Leicester Street, Walsall during WW2 and watching the huge beam racing skywards as the crew lit up the light.
Dennis, just a point of interest, would that type of model searchlight you purchased 'fit' in the 251 rear compartment space. It looks rather large, I have not been able to find dimensions for the one on eBay. Having said that, I am very taken by your 'Flak' arrangement....decisions, decisions, decisions..... :roll:
Dennis Jones
Has liked: 10 times
Re: SdKfz 251 build
Hi Mick,
Yes it would go in there but you would have to cut the seat off if you wanted it to rotate and probably build a false floor as I have done to mount it. That would also come on handy to mount the electronics under.
The dimensions are with the seat on :- 11" long by 8" wide and 9" high. Without the seat on the length would be 10" and the rotary table is 6" in diam. So you need 6" diam clearance to rotate it without the seat on, with the seat on about 9" diam clearance.
Flak 38 Dragon gun very difficult to get hold of, I did see one in the States for $50 but they wanted another $50 to ship it.
How goes the riveting ?
michael hilton
Re: SdKfz 251 build
Hello Dennis and thank you for the searchlight measurements. Might just go for it :D
Now......regarding the rivets, I have cheated....most of the 'rivets' have been replaced by button head M2.5 x 4 bolts and nuts. Once satisfied with the location I fill the 'head' with Milliput, when painted they resemble rivets.....magic. Unfortunately my 'shaky' hands made a mess of my early riveting....so where needs must as the saying goes. It's called 'stand off' scale. 8)
What a glorious morning, so into the garden for some paint spraying.....
I follow all the builds on the Forum, some really serious modelling going on, well done everyone....Mick
Beware of trains
Beware of trains
michael hilton
Re: SdKfz 251 build
Hello lads and lassies, steady progress, looking forward to the options pack. The Sdkfz 251 in 1/6 is an easy manageable size, without the weight. A problem I had to consider, old age does not come on it's own....
Most of the body 'sections' are built and ready for final paint. I am still pondering the rear compartment layout.....Mick.
Dry fit
Dry fit
Dennis Jones
Has liked: 10 times
Re: SdKfz 251 build
Hi Mick,
Looking good. You can put the batteries in the front with the body on by the way. 2 x 9 amp/hour 12 volt batts will go in through the bonnet opening.
duncanallender
Been liked: 8 times
Re: SdKfz 251 build
Post by duncanallender »
Hi Dennis. Do you know of where I could get such Batteries from and what make they are. Still looking for some smaller ones for Clive Lockwoods old M3?? Cheers
Duncan
michaelthompson
Been liked: 8 times
Re: SdKfz 251 build
Post by michaelthompson »
michael hilton
Re: SdKfz 251 build
Hello Dennis, thank you for the advice reference batteries, I had planned to ask you. I will order my batteries tomorrow from Hardware Express, I have used them before.
My Options Pack arrived today, I like the new 'slim line' modules, the motion unit will fit under the floor leaving plenty of room under the bonnet. Can't wait to 'fire' it up.
Working on the cab area, fitting lights on the dash.....Mick.
A quick preview
A quick preview
