Tiger I ausf.E/45 2012
- Has liked: 26 times
- Been liked: 103 times
Re: Tiger I ausf.E/45 2012
G'day Gerritt. What type of bearings did you use? That is a great idea. Can you take a closer photo of the bearing? Cheers Ray.
- Been liked: 15 times
Ball bearings from Peter Quambush.
Hallo Ray,
Yust have a look ad the forum; Ball bearings for the KT tuuret from Peter Quambush.
You will see all the details you need.
Kind regards Gerrit.
Hallo to all,
Here some result from the past and new stuff.
I try to make my Zimmerit with acrylaat-kit.
Also a transport container for the Tiger I for a save transport into the car.
Make a new wired deck rooster.
New gadgets
Manfred looks and it is OK.
I will first make the undersite of the hull and then I will see.
Cheers Gerrit.
New gadgets
Cheers Gerrit.
- Been liked: 223 times
Hi Gerrit,
Nice accessories you are collecting,I like your new Mesh
cover,be carefull that Manfred doesnt step back on it,he
looks as though he is concentrating more on your fuel drum.
Hallo you iron tankers,
Here some results from the weekend and a update from Manfred aus der Werkstatte.
Zimmeritscraper from scrab.
My first result and I am pleased.
The undersite is now sandyellow.
Manfred is now bussy with the modules to place it into the right postion.
There will be a alu-plate with all the modules and gap for the turretmotor.
Manfred will be back on next weekend.
Gruss from Manfred and Der Alte.
Nice work with the Zimmerit Gerrit,
I like the way you are organising your electriacal equipment.
That one photo of your hull from the side was deceiving to the eye,
the Hull looked as if it had been shortened by the camera
Hy Phil,phil fitzpatrick wrote:Nice work with the Zimmerit Gerrit,
the Hull looked as if it had been shortened by the camera![]()
Can you explane what are you meening with the last anser, because I dont't understaned?
Thanks anyway for the complements.
Cheers Gerrit.
Hi Gerrit,
The last part was jusr about the way the camera made the photograph of your Hull
look shorter,nothing wrong.
before that I was just saying how I liked the way you are putting your electric parts
on panels the same as your switches.
Hi Phil,
OK, now I know what your are meening.
It is possible that the possision off the camera make the difference.
The electric solution is a special from my old work that I used too be an chiefelectrician so Phil I still have my skills.
Cheers Gerrit.
Cheers Gerrit.
Hallo to all,
Here some results from Manfred aus der Werkstatte.
The new ramps are sublime.
Also the smoke unti 1/4 turn mountend for the extra space accumontage.
All 3 battery's now are flat mounted.
The speakers and modules I placed on differend wooden boards.
I can see everyting via the turret of the electronic's is OK.(if you now what I mean)
Manfred is now trying to make the DEVIL for a ride.
The best greetings from a sunny Holland.
Cheers Gerrit.
Cheers Gerrit.
Nice work Gerrit
I like your Ramps and the nice layout of your control box's on
the wooden board.
the wooden board.
- Has liked: 10 times
- Been liked: 224 times
Gerrit,
Are you fitting a remote on/off switch for the power supply if not how are you going to get to the switch on the power supply.
Hallo Dennis,
I make a main powerswitch (manual) between the 24 v battery plug (F) and the battery 24v+.
See my picture (page 3) on my site.
It is on the backsite off the Tiger.
Best regards Gerrit.
Hi Gerrit,
I meant the red power button on the power supply module.
