Page 4 of 9
Posted: Sun Feb 13, 2011 5:30 pm
by Luca Fossa
Great work Steve, my best compliment
cheers
Luca
Posted: Sun Feb 13, 2011 9:29 pm
by Pierluigi Patri
Wonderful work, Steve :shock:
Posted: Mon Feb 14, 2011 1:14 pm
by Kent Wiik
Steve Norris wrote: Kent,
There is a 4mm gap between the swing arm and hull side
Thanks Steve, much appreciated.
4mm that will do so now another one to the "must have list"...
Another question now when I look at the photo I posted above.
This new release Panther kit does it have the hull bottom plate divided with a thicker one at the front? (as I believe the KT kit had looking at builders photos).
I have been told it is now made of aluminium and that sounds good.
Reason for asking is that I am putting up a list of upgrading parts for my own build to order from Gill.
Thanks in advance.
Posted: Mon Feb 14, 2011 2:34 pm
by Steve Norris
Hi Kent.
After a trail fit of the Anschlagbock i have come to the conclusion that the set up i have does not give enough clearance between the bolt heads and swing arm, the bolt heads protrude almost 1mm and just touch the swing arm. After a rethink i am going to drill all the bolt positions 11/32" through the plate to simulate the counterbores then attach the plate to the hull side using 3x M3 csk bolts which will be filled so that they will not be visable. The bolts will then be fitted into the drilled holes.
I will post some photos soon to show what i have done.
The Hull bottom plate is indeed ally, but just 1 piece without any step.
Posted: Mon Feb 14, 2011 3:10 pm
by Kent Wiik
Steve Norris wrote:The Hull bottom plate is indeed ally, but just 1 piece without any step.
Thanks!
Ok, no problem I have to go for plan B instead.
I think I got the picture and believe the csk bolts will be the way to go.
Has a good photo of the Houffalize Panther from Sven Strobbe that I think he wants for everyone to see.
Might give a hint how this one looked, please note how the bolt heads are "sunken" into the holes.
The "tube" left/high has nothing to do with a real Panther it’s just to get wheels on this display relic.
Posted: Mon Feb 14, 2011 11:36 pm
by Steve Norris
A little update on the Ansclagbock.
The first shot shows the dummy attachment bolts in position, 2 more bolts fit forward of these but because of the position of one of the torsion bar block attachment screws it was not possible to drill and tap at that position. Also shown are 3 predrilled and tapped holes for attaching the Anschlagbock plate.
The next shot shows the Anschlagbock plate installed using 3 M3 csk bolts.
The next shot shows the final appearance of the Ansclagbock with the mounting screws filled and the 2 dummy bolts glued in place
The final shot is for Kent showing the inside face of the Ansclagbock with the mount bolts retained by lock tabs
More to come
Posted: Tue Feb 15, 2011 8:23 am
by Kent Wiik
Nice Steve, super work!
Spot on with the bends at the lock tabs and everything else.
Good inspiration, thanks.
Posted: Fri Feb 18, 2011 8:47 pm
by Steve Norris
The next bits !
The hull sides have covers over internal suspension fittings so instead of cutting these individualy from sheet metal i decided to see if i could cast them.
This was the result.
After an evenings casting i had the 16 i needed.
A bit of clean up and primer and almost ready to fit
A bit of carefull marking out and drilling and the hull sides look like a seive.
Covers fitted, looking a lot better.
Finally a couple of closer shots showing the covers and additional bolts and fittings.
A very pleasing result but unfortunatly not a lot will be visable with the wheels on, But at least i know its there.
Posted: Fri Feb 18, 2011 10:38 pm
Great looking parts Steve - were they dificult to cast ?
I'm surprised you appear to have done them vertically - but I suppose that stops you getting the dropped soufflé effect if they were flat ?
Posted: Fri Feb 18, 2011 10:49 pm
by simon_manning
a master class in detail i knew it would be done, i like it , i might go for this level now i've seen the result, superb steve, regards simon.
Posted: Sat Feb 19, 2011 12:33 am
by Brian Leach
Steve,
This is an excellent build. The detail!
Now you need to cast some brass Swingarms for the suspension!
Hey, thanks for sharing, good job!
Brian
Posted: Sat Feb 19, 2011 10:24 am
by Paul Morris
Hi Steve.
Looking really good mate, you set the bar pretty high with your first Panther but this is going to beat it. Good stuff!
Cheers Paul :wink:
Posted: Sat Feb 19, 2011 7:25 pm
by David Gray
exellent detail Steve , didnt realise there was so much on the
Panther
Dave Gray :D
Posted: Sat Feb 19, 2011 7:45 pm
by Steve Norris
Hi Gents.
Thanks for all the positive comments.
Adrian, I spent quite a while thinking how best to produce the covers as i did not fancy cutting out 16 from sheet metal. Casting was the easiest way for me to produce these and after some thought i went for the method shown as i guessed it would produce parts with the least clean up to do. I was very pleased with results as they were all nice and flat with just the casting sprues and acouple of lumps and bumps to clean up.
Back to my next casting job
Posted: Sat Feb 19, 2011 8:47 pm
by John Fitzsimons
Nice castings. Love the details going in there. Did a lot of casting myself in the past. Hope I can add something of my own to my tiger.
This is going to be an amazing build. Well done.
