Hi Guys
I kept wondering what the hole was for in the bottom of the ratchet,then
I found it on page 861,in the Chief Inspector of Fighting Vehicles,Comet 1
Handbook.
There was a peg in the hull and an extension spring that holds the ratchet
into mesh when the lock nuts are loosened,when the crew adjusted the
Track tension.
Which the manual says "Insert the end of the adjusting lever into one of the two slots and using the full efforts of three men,lever upwards untill the correct tension is obtained".
So I fitted a peg and found two spring to suit and switched my lock nut arround to the other side.
