Mr Dawe's Centurion.
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Re: Mr Dawe's Centurion.
Post by Oliver Brüninghaus »
Not an easy task but it will be perfect as always!
It's Grim Up North
Has liked: 2259 times
Been liked: 7149 times
I hope so Oliver
Off we go there's no turning back back now
Reference photo
Reference photo
This is well stuck in
Some work needed here
A few casting numbers always helps
Reproducing the tooling marks and the sand casting texture
The grey primer shows up any imperfections
Building up the texture, stippling this time
The turret vent must go
The new position of the search light power cable outlet
I'm happy with it so far
Smore done on this damp early winters day
Thank you Stephen
Thank you Stephen
DSC_0056[1] (4).jpg (39.96 KiB) Viewed 1427 times
Reference photo for the ammunition hatch work
This will be a perfect hole circle because...
.....I'm using the hole circle feature on the dro
Milling the small parts
The chunky hinge detail now made and fitted to the ammunition hatch
The base nearly done
Turning up the fittings for the search light junction box
Extension piece for the ammunition hatch
Just need to ad the cable for the search light but not yet
Done for now until I get the milliput out again
Phil Dawe
Has liked: 755 times
Been liked: 276 times
Post by Phil Dawe »
Lovely stuff Phil. Huge thanks to Centurion expert Stephen White and the archive staff at Bovington TM for keeping us supplied with detailing info. :D
Lots done on the machines.
Always printing something
I've printed a reduced version of the side lights which looks the part for these electrical outlet pieces
The scope mount aperture needs milling out to get that recessed look
The turret is a bit big for the mill table but it copes very well
The nr side antenna mount blank, not used but worth the addition to create detail  interest
Filling and blending and weld beads to get the look
Following the lines rather than the numbers
That's a 28 mm hole made using a 12 mm end mill without a rotary table
If I can I will use off cuts so nothing is wasted
Cutting the antenna mounts.
Hole circles.
Hole circles.
Those clamp marks will add to the turret texture no doubt
Blending in is now required.
Michael Cecil
Has liked: 73 times
Been liked: 109 times
Post by Michael Cecil »
Nice work. Not familiar with that placement of the Larkspur series aerial bases: do you have a reference, please?
Mike
I can send you one of the reference photos by email Michael but it can't be published in any way due to the copyright but I will just check with the boss first .
Michael Cecil
Has liked: 73 times
Thanks. Email sent.
Mike
Kevin Hunter
Has liked: 597 times
Been liked: 142 times
Post by Kevin Hunter »
I was intrigued also. Couldn’t see a pic in the Wings & Wheels book that you’re using either!
Some great work going on here as usual…..regardless.
Kevin
Shame we can't post the reference photos.
Periscope mount blank ready for turning
Milling the periscope mount
Pivoting periscope tube mount
A lower profile for the front angle required
I need to profile the front cover, add a bracket to the rear, add blinkers and stiffening pieces to the lid
Finished the loaders sight.
There's a nice big gap to fill now, I couldn't get the angle on the mill so had to do it this way
Milliput blending stage one to the antenna bases
I will have to apply the milliput in two stages as working the weld beads whilst the filling is soft will cause many problems
The correct turret casting numbers for this later turret now in place. Thank you Mike.
Ammunition hatch now finished and weld bead added
The tie down loops are too big so new ones with weld detail need making and fitting
Lots done, and at the pointy end to.
The new tie down loops just need the weld detail
Filling required
Filling required
A mk6/1 example
A mk6/1 example
Some setting up required here
The new tie down loops made and fitted, it's amazing how something so small can make such a difference to the look.
Following the lines again
I'm happy with the cutaway
Some milling out required here
Brass sleeve made
Brass sleeve made
Nice brass sleeve fitted
Turning up a basic ranging gun barrel
I believe the ranging gun was .5" but what caliber was the coax?
First stage milliput will need some rubbing down once cured
Although you won't see a lot of this work it will provide the correct stuffing for the canvas cover
Kevin Hunter
Superb as always Phil.
Better men than me will tell you the co-ax was 0.30 and the ranging gun was a 0.50.
Kevin
Michael Cecil
Has liked: 73 times
Cartridge:
Coax: .30-06
RG: .50 BMG. The round was the L11A1 or L11A2 'flash-puff' round.
Weapon nomenclature was:
coax: L3A3 (or if earlier than about 1960, M1919A4) Edit: for Mk.5 and beyond.
RG: L6A1 (Edit: if fitted, Mk5 and beyond)
Mike
Chris Hall
Has liked: 516 times
Been liked: 671 times
Post by Chris Hall »
Or, if you go retro (Mark 3) the co-ax is a 7.9mm Besa.
Not sure about the ranging gun - a 20mm Polsten ?
:wink: :lol:
