- Has liked: 760 times
- Been liked: 1732 times
That looks awesome Phil. The other Phil will be well chuffed with it.
- Brian Ostlind
- Has liked: 965 times
- Been liked: 2066 times
Love the pictures. Really puts a smile on my face to see such a beautiful model.
- Has liked: 2254 times
- Been liked: 7137 times
Many thanks guys much appreciated. We are awaiting the engine deck grills and the near side sprocket but other than that she's all done, the tracks are still a bit tight but will settle as will the suspension. I did forget to fit the lovely stab antenna for the photos. The running trials went well, she's now on single stick control, what a performance to set that up using the Spektrum DX6e , the knowledge base was very helpful, if your new to the hobby I doubt that you could set it up without it but there's so many tx tweaks to get it to work ( and you have to use aux1 channel, not the gear channel ) it's still a mine field! 8
- Has liked: 8 times
- Been liked: 688 times
Hi Phil
That looks the dogs danglies now it’s done, wasn’t sure about the winter camo at first but now it’s complete everything blends into a very convincing replica. Your customer should be very happy with his new Tiger.
- Has liked: 2488 times
- Been liked: 443 times
The level of detail you have added to the model makes it more realistic, I have always been a fan of " through the hatch" detail this changes it from a model to a scale replica in my opinion, well done.
- Has liked: 1022 times
- Been liked: 2090 times
Thanks Phil, glad the Knowledge Base was a help. Always good to get feedback. It does need updating but unless there's positive feedback it hardly seems worth the effort. Great model and enjoyed reading your blog.
- Been liked: 1715 times
Wonderful Build Phil
Fantastic detail. But also fantastic because it actually works, moves and lives.
As an engineer, I appreciate models that do what the original was designed to do.
Static's are great, if you want a snapshot.
If you can achieve self propelled and static detail, well, that's a step up.......... my opinion.
and it's all here.
There's No swinging rusty buckets here either
and it's all here.
Thanks guys you are the judge and jury and i'm happy with the verdict, I was a bit unsure of the winter camo request mainly as I have seen some very unconvincing examples and never applied white wash to this extent before but i'm very happy with the end result!
Thanks to Phil ( the boss) for asking me to build the Tiger, for me and him it's been a huge amount of work in a relatively short space of time but it's been a pleasure indeed.
I believe he has a RR armoured car that is next on the list for me, that should be something different! That Chieftain is calling right now!
- Has liked: 115 times
- Been liked: 2 times
Thanks for posting this build Phil. Much appreciated, really helpful. Bob
Bob & Graeme
Installed the engine deck grills and fitted the nr side sprocket, nearly all done just a few hand tools to paint and weather and place in the tool boxes, unit marking for the glasis plate , oh and an antifreeze drum to place somewhere. Then the boss can come fetch her
- mark j. radick
- Has liked: 393 times
- Been liked: 538 times
- Been liked: 735 times
Hi Phil,
please can you tell me how big these pieces are? (I mean the square profiles)
Thank you very much Ivano
- CLAMP.jpg (121.88 KiB) Viewed 2968 times
Hi Ivano, the tiger is in the machine shop right now, I will have a !look in my spares box tomorrow, Kind regards Phil
There you go Phil the barrel is now white and weathered and the turret numbers are toned down a tad.
Loving it Phil! All I need to do now is find the time to come and pick it up
