Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Final detailing and painting for this sub assembly
So I'm going for red oxide, off white and of course silver
Seat cushions are leather green
Must not forget the compartments top piece
Building up the weathering
Decals go on
Decals go on
I think that's enough for this piece
Nearly there with the drivers compartment
Making up Armorpax superb fire extinguishers
The seat weathered
The seat weathered
Enough weathering for now on this piece
Before the weathering wash
And after.....It's so easy
The fire extinguisher now fitted, there is another to fit above the drivers left knee
The weathering is that easy
The last job of the day .....The canvas curtain between the drivers compartment and the turret
Just needs and edging strip with some tie back webbing straps
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
All we need now is my 5 ' 4" driver to park his butt in the seat! :)
A tad more done today
The canvas screen needs a little weathering
And that's about it for the drivers compartment.
"That's about it" my arse! There's more detail as in leds and one last hatch.
We have had a lighting strike Sunday lunchtime and our internet router has been fried so I'm using my phone via a " hot spot" backup
Finishing off the canvas curtain with a little paint and weathering
Great little leds for just this kind of job
Always touching up to do as we go
Spot the tiny leds on the instrument panel
Can you spot the little touches that litter the floor here and there?
The very last access hatch made and fitted, this hatch was next to the drivers left knee
Phil Dawe
Post by Phil Dawe »
An illuminating report Phil!
Mainly wiring today so not much to report.
All the vehicle lighting is now on the switch panel in the drivers compartment , the convoy light, the turret lighting, the search light, the head lights and the side lights are all switched from the drivers compartment, the instrument panels leds are live if the vehicle's main switch is on.
It is all labelled!
It is all labelled!
Well I know what it all does.
Wiring all done for now, onto the turret.
I'm starting at the very highest point
Anybody know anything about this periscope blank behind and underneath the hatch assister spring?
Reference photo for the inner hatch profile
Off we go
Off we go
Bull nose cutter
Bull nose cutter
Simply put, for every 1 mm off the y axis dia the z axis moves down .25 mm
Dished
Dished
Plasticard disc cut out
With a little heat the turret hatch head piece cushion molds into place by gravity
Dished
Dished
Has liked: 1022 times
Been liked: 2093 times
Very nicely done on the Driver's pit, Phil, just needs fag packets, cotton waste and general military litter...
"Anybody know anything about this periscope blank behind and underneath the hatch assister spring?"
Try these, more work I'm afraid.
Bovvy Mk 3, cupola trained aft
1/6th
1/6th
Aussie Mk 5/1
Aussie Mk 5/1
DSC_0093[1] (2).jpg (46.91 KiB) Viewed 1391 times
1/6th
1/6th
Work indeed.....thankyou sir!
Lots to do with the detailing that the turret lacks.
I'm going to use this piece of cloth which has a good patina to start with
Inner hatch commanders  sweed padding
Milling the hatch hinge slots
That blank needs removing
The blank removed and the periscope made and fitted
Milling the armour piece
I'm using my milled peg mount method for the armour piece
The rear facing periscope added with armour
Hatch handle added
Hatch handle added
The hatch lock added
It's amazing how the transformation evolves even with just a few details it looks so much better
Phil Dawe
Post by Phil Dawe »
Huge thanks to Stephen White for his detailing info. Thank goodness there are people like you sitting on tons of useful info for situations like this!
The cupola detail is quite extensive, the more you look the more you see.
There a lot to do here
I had to drill through from the underneath to knock out the periscopes
A question for those that know, was this weather piece made of rubber or canvas? ( the pencil is <br />pointing at the weather piece)
Each of the periscopes needs machine out
The offset periscope x one
I need to make the binocular sight
Using the old periscope blank as a base for the binocular site
Casting the periscope lenses, don't know what I would do without the clear resin
You can clearly see the odd angle of that periscope
Last job of the day was to go cast the binocular scope lenses
Frank Breitenbach
Has liked: 54 times
Been liked: 689 times
Post by Frank Breitenbach »
Hello Phil
Today I look into the forum and I see your building report: Really excelent!
All the best
Frank
Gary Richardson
Has liked: 726 times
Been liked: 1667 times
Post by Gary Richardson »
Hi Phil
I am thoroughly enjoying your build, your attention to detail is an inspiration. Fantastic job, keep up the good work.
Gary
