Page 28 of 95
Posted: Mon Jan 13, 2020 12:42 pm
by Phil Woollard
Many thanks for those photos Steve
Posted: Mon Jan 13, 2020 5:41 pm
by Phil Woollard
Some more progress.
more words when I have been fed and watered.
Posted: Tue Jan 14, 2020 5:19 pm
by Phil Woollard
Busy day in the workshop.
Posted: Tue Jan 14, 2020 6:17 pm
by Kevin Hunter
still loving every second of this build Phil, amazing work and so many hints and tips for those of us less gifted. Thankyou on behalf of the forum as a whole, those of us with Chieftains to build in particular.
As for the sidelights...... “yes please”, obviously
Kevin
Posted: Tue Jan 14, 2020 6:24 pm
by Stephen White
"At present the turret touches the rear deck"
That's because the kit hull is raised in the area of the engine covers. On the real Chieftain, it's only the transmission decks which were raised, in order to accommodate an increased capacity exhaust system. If anyone chooses to enhance the accuracy of the model, it will require "engine deck lowering" - sounds familiar to anyone who built one of the first Tiger models?
Posted: Tue Jan 14, 2020 6:35 pm
by Phil Woollard
Cheers Kevin and I will post the side light pics tomorrow, Stephen Ivano will have a fit with any less room for the engine!
Oh I found this photo of the rear bin. The photo caption refers to the "red lead" stowage bin lid and interior.
I'm looking for a good photo of the front lights wiring route if anyone has any I would be so grateful!
Posted: Tue Jan 14, 2020 9:02 pm
by John Clarke
Stephen White wrote: ↑Tue Jan 14, 2020 6:24 pm
I once worked for an engineer that would pace out a wiring job. He thought one stride was a meter, we worked it out it was only a yard.
For a leaving present we gave him a quality tape measure with the first inch removed.
So,I'm buying more kebab's then?
Posted: Tue Jan 14, 2020 10:19 pm
by Richard Goodwin
This is probably a daft question Phil but have you got the spacer ring and toothed drive ring attached to the turret? It seems to me you only need the height of the spacer ring to clear the deck.
Posted: Wed Jan 15, 2020 12:42 am
by John Clarke
I don't think putting the spacer either side of the toothed ring would make any difference if that's what your saying Richard.
During Youngjae's build, he wrote
"I put a turret in the tank body today.
At first, I made it like a manual, set it up, then turned the bolts and turret that secure the wedge rails and leveled the turret at about 20ea of 5mm washers before I realized that the interference would go away and spin very smoothly."
If we look at his super clear pictures we can see what appears to be long set screws, nuts and spacers attaching the toothed ring and spacer to the turret, Lifting the turret 5 mm off the bearing ring.
Seeing the turret fitted, we can now see the gap generated by the spacers
- 20191124_20570612.jpg (91.87 KiB) Viewed 806 times
- 20200112_221343.jpg (59.36 KiB) Viewed 806 times
By shaving some material off the underside of the rear of the turret I'm sure you'll be able to clear the deck like with the Armortek build. The gap between the turret to the front plate armor is a lot less. I also noticed that the turret roof plate is slightly bent upwards allowing the whole bustle to be lifted at the back end, a little more clearance needed possibly?
- 79333140_10157922765703792_6930786470697369600_o11.jpg (57.59 KiB) Viewed 806 times
Or just change the rear deck like Stephen suggests.
Posted: Wed Jan 15, 2020 8:40 am
by Phil Woollard
We also need to reduce the thickness of the drivers hatch too!
Posted: Wed Jan 15, 2020 11:16 am
by John Clarke
Oh yes, the "Slab" that should be fun.
Once it's been thinned out, the lifting bolt/shaft will be more exposed.
In the model boat world you can buy small rubber bellows units quite cheaply on fleabay
Put in search or something like it.
Rubber Bellows Fittings RC Boat 2pcs Push Rod Seal Radio Kit Replacement Parts
Ideal for the hatch lifting bolt/shaft cover bellows. Put a light spring inside the bellows and you have a pop up hatch!
You could use one of your latches to hold the hatch down too.
- s-l1.jpg (105.04 KiB) Viewed 751 times
Posted: Wed Jan 15, 2020 12:31 pm
by Phil Woollard
They look good, I will take a gander
see below John I have cut the drivers hatch down, please note the section is tapered, thicker at the front thinner at the rear, or is it the other way round? Now the recess needs sorting out.
Posted: Wed Jan 15, 2020 1:05 pm
by Shaun Hunt
Hi All
Out of curiosity I had to test fit my turret, all looks ok.
The gap is small but there is clearance for the rear of the turret. I have not used any extra spacers
Posted: Wed Jan 15, 2020 1:08 pm
by Shaun Hunt
Hi Phil,
Great looking build by the way, I hope my build turns out as good, I don't have the machinery to attempt any of the really extensive mods on the hull.
Posted: Wed Jan 15, 2020 1:15 pm
by Phil Woollard
Hi Shaun, maybe keep an eye on the clearance issue as you add more parts, you may be lucky but it's no big deal, I shall remove some of the underside of the turret or add shims ....what ever seems more appropriate.
The side lights.
