Hello Phil, thank you for all you patience and perseverance......
I now have the Loom Plug and Socket leads in the right order......
The motor runs one way and stops by pressing one limit switch.....
The motor will not reverse, I have tried moving the limit switch leads.....
I don't want to disturb the leads already corrected.
The only other unit to check is the Auxiliary Module.
Could you tell me if the Auxiliary Module leads are correct....
This is how mine are fitted.On the spade connectors from left to right.
Blue Brown Yellow White
The white plug with the green dot, left to right
Black Green Red Purple.
I have not moved any of these leads......Mick
