Pz III New Build
Antony Rowley
Location: Back to Wirral home of the brave or not so brave, England
Post by Antony Rowley »
Hi Stephen,
I'm really enjoying your build :D.
Your Pz III looks, from some photo's, REAL :!: Your attention to detail is superb. Keep the photo's coming.
Superb Panzer and a great build :wink:
Thanks Antony
Been liked: 1634 times
i must agree with anthony this build is and has been very interesting, a lot of skill and stamina, regards simon manning.
Has liked: 1024 times
Been liked: 2093 times
Update
The hull applique armour is now complete with the side plates and welds:
Next the mounts for the Unterlegklotz, (jacking block) and the finished block from Mike Stannard, finished with Promodeller washes and their new pigments:
I made a late model Brechstange (pry bar) by turning down a 6mm brass rod, annealing and shaping the end, together with the mountings:
Finally, I've started a scratch build mount for the shovel, soldered up from brass:
This is a rewarding bit of the build, becaused everything is a one-off, unlike the repetitive stages of the running gear. Pity Mark, who is wading through 2000 Panther road wheels..........
As always, I'm sounding like a broken record. :?
Excellent parts Stephen. Amazed at how easy you make this stuff look.
Completed the fittings for the shovel and axe. Tim, second time around, I remembered to use a heat sink to prevent the whole assembly springing apart with the final bit of soldering....
Next the antenna mounting.
Antenna Mounting
Turned a new antenna mounting to scale and added the weld detail:
Having seen the expertise of those like Tim and Mark who know their way around a CAD package, a humble sketch seems a bit redundant but it's the only way I could make sense of the typically Wehrmacht over-engineered antenna coupling. This is one case where a 2D engineering drawing doesn't really help.
I can see a weekend of "trouble at t'mill" coming up.
Has liked: 126 times
Been liked: 755 times
Steve,
Your detail parts are really impressive. Close up your P3 looks like a real one in the museum. The antenna base looks like it was really welded together. Great work! Keep it up, you are inspiring us all.
i thought that was the bovington tank in the mueseum,very nice, regards simon manning.
Antenna coupling
A day with the lathe and mill, to complete the antenna coupling parts.
This is the Bovington tank, from which I made the drawings. For once, the drawings in Jentz and Doyle are don't capture the detail accurately, the shapes are quite complex:
Here are the basic bits:
There is still some finishing to do and the springs will need to be added:
I've used Mike Stannard's 2m Stabantenna although I might turn one later with the correct constant taper.
Stewart Ashton
Been liked: 1 time
Post by Stewart Ashton »
Stephen your work on this model is fabulous as usual 8)
Regards Stewart
Has liked: 1371 times
Been liked: 1567 times
Glorious detail once again Stephen :D
Antenna Coupling - More
More progress on the antenna coupling, including the two side springs and the fore and aft stays. Nearly done:
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Stephen,
Not seeing your wonderful work has been what I have missed most on the forum.
That antenna is, what can I say, really good, great? It truly is inspiring, as well as the other work you have done in the last couple of months. In some of the pictures it is difficult to tell if it is the real thing or your work. That is, to me, the highest complement. Well done!
Thank you for sharing. I am not into the Comet, but I will be sure to watch.
Brian
Brian
excellent stephen, great skill! one for the memory banks i think, regards simon manning.
Brian, Simon, thanks for taking the trouble to comment. Much appreciated.
Here's the final result:
I then spent the rest of the day discovering how difficult it is to turn a tapered antenna without it snapping as it gets to the critical thickness. Oh well.
