Page 25 of 54
Re: Mr Dawe's Centurion.
Posted: Wed Sep 28, 2022 5:57 pm
by Phil Woollard
Onto the bigger jobs now so more photos and more to see. Just to let you guys know that don't already know, I have recently had a cancer scare but all is fine now I'm going to live!
Posted: Thu Sep 29, 2022 6:05 pm
by Phil Woollard
The periscope will need a coat of olive drab but not just yet.
I'm still working on the smoker and working out a way to plumb the engine exhausts in with the high pressure smoker outlet.
Posted: Fri Sep 30, 2022 5:57 pm
by Phil Woollard
Getting on.
Posted: Tue Oct 04, 2022 5:54 pm
by Phil Woollard
Mainly wiring today.
Posted: Tue Oct 04, 2022 10:56 pm
The signal lead goes into OUT3+4 on the Benedini board, so the top set of pins in your picture.
They should both be have the same output but I would try it with the white lead at the bottom and the red lead in the centre to start with.
Posted: Wed Oct 05, 2022 11:36 am
by Phil Woollard
Thanks Adrian, I'm assuming that your lovely unit is 24v in and the output is regulated/proportional fan speed out of 24v as before, also how many amps do I have available on the output now?
Posted: Wed Oct 05, 2022 5:55 pm
by Phil Woollard
More wiring.
Posted: Fri Oct 07, 2022 5:50 pm
by Phil Woollard
A good afternoon's work.
A couple of questions for Adrian, what are the working voltages of your unit please, Ie input voltage range?
How many amps do I have to play with regarding fan loading?
Posted: Sat Oct 08, 2022 11:01 am
by Kevin Hunter
Outstanding work, and great reading as always Phil.
Out of curiosity did you use Armorpax filler caps? I looked at them many years ago but was never sure they were the right size.
Keep it up.
Kevin
Posted: Sat Oct 08, 2022 12:42 pm
by Phil Woollard
Hi Kevin without going over the top I try to keep it interesting lol, yes the filler caps are Armorpax .
Posted: Sun Oct 09, 2022 11:12 am
It's rated up to 36V and 5A without a heatsink, though probably good for up to 7 or 8 amps I would think.
Posted: Sun Oct 09, 2022 1:10 pm
by Phil Woollard
Thanks Adrian, the unit is working very well I just have a bad motor on the air pump.
Another question, which side of the equation would you have the speed controller, before your unit or after? I use the speed controller to set the optimum air pump speed as every system I build is slightly different. Thanks in advance Phil.
Posted: Sun Oct 09, 2022 3:01 pm
I would put the controller in front of my unit, as continually interrupting the supply to the controller probably wouldn't do it any favours.
Posted: Sun Oct 09, 2022 3:40 pm
by Phil Woollard
That's what I thought, have you ever considered making a device to give us track recoil when the main gun fires? Surely every owner would want one of those too!
Posted: Sun Oct 09, 2022 5:24 pm
To make it visible would put a huge amount of stress on the motors and gearboxes.
From what I've seen of tanks firing, they hardly rock anyway.
