OPEN ON THE 6TH FEB 2025
Has liked: 2267 times
Been liked: 7152 times
I've been very busy but you will have to wait for tomorrows detailed update. 8)
I have booked some time on the big milling machine to cut the recess in that mantlet pivot so the breech sits in the right forward position and the coax has a home, the loaders sight may be compromised due to the elevation mechanism.
Yesterdays resin and white metal work.
You can see the elevation mantlet mount slot under the left side of the breech, this will need to be re positioned as far left as I can get it, im not sure what can be done with the loaders gun sight just yet but we should be able to squeeze it in.
The breech is locked in the open position with a round half way in.
The warming and straightening of the out of shape resin parts is a very important skill, this is one of the turret vision port covers which would not line up with its hinge.
Lots of small resin parts to clean up and prime. Most of these parts are for the coax mg mount.
The hull mg bag of parts.
What it should look like in blue!
Lots of cleaning up to bring out the detail.
Been liked: 1644 times
I like to comment on a builder that takes the effort to post his / her progress, it make's the forum what it is, Lively and interesting, thanks phil, regards simon manning.
Thanks Simon it sure is a lot of effort. I have had a good day so here's a taster for tomorrows post. 8)
As promised more progress photos, I hope to be on the milling machine after lunch and get that mantlet mount hollowed out to accept that 88 breech.
The parts are coming together now, you just have to identify a piece using the limited late Tiger photos as reference and plod on. More detail will be added to the breech when I am happy with the fit.
Space will be at a premium in there, I also want to add a full crew, so it will be packed!
The new fittings drilled and tapped with grub screws to hold the de mountable turret basket legs.
I have made new turret basket fittings from brass water pipe brackets.
The new fitting, stronger in brass and bolted in place
Wading through all these parts but the pile is getting smaller by the day.
Just got to rub back the mg body to remove some of that shinny paint.
One of Tim's master pieces.
First stage of the weathering, another darker colour to be applied then top coat then rub back.
A taster for tomorrows post. 8) To include one for the bosses attention. I'm off to a plant sale ( as in diggers and stuff ) tomorrow, they have a Chieftain bridge layer and a CET , that's 1/1 size....now do I bid if they are cheap enough?
Sorry Liam , your beautiful steel track links burnt and about to be immersed in salt water for a few days.
The machining went well today.
Same as this one boss an mg 34.
Has liked: 775 times
Been liked: 1740 times
Phil, I think that with the amount of detail you are putting in the turret, the elevation mechanism is really going to look out of place. Just my opinion.
Liam Mahoney
Been liked: 299 times
Post by Liam Mahoney »
Hi Phil
Glad they arrived but I am not sure that you needed the heat a wash with degreaser and they go rusty in just plain water?
Liam
I like my accelerated version Liam! Vince you maybe right but it will be bolted so if the boss wants to remove it then he can, more photos from yesterdays work.
Liams track links so looks good.
The flames burn off any coatings and really accelerate the rust process
The salt water bath to rust those steel tracks
The elevation mech is ugly but I may be able to disguise it some what.
Before machining
Before machining
After machining
After machining
I seem to be making a habit of the evening preview of tomorrows progress post. Much more in Fridays update.
It's getting pretty full in there
Looking through the commanders hatch.
I have made new ali turret basket legs so the whole thing is capable of supporting its own weight when the turret is removed for maintenance.
Yesterdays turret basket update. 8)
Totally free standing, just lift out.
I now need to make the late T1 storage lockers either side of the turret
That elevation mech is not so prominent as it kinda gets lost in all the myriad of parts, I may make a simple shroud to cover the motor further.
Thats my last metal mg 34, which looks so much better.
Now everything is bolted to the turret, this allows me to remove the unit to add detail, paint and weather those parts as there's not much room in there. It just shows you the restricted space that the crews had to operate in, even in a relatively large tank like the Tiger 1 the fighting compartment was in no way spacious!
I rather like these photos of all the workings from this angle, I wish that there were more like this on the Web.
I do like the 88 counter balance/damper
You can just see the tops of one of the main batteries in this shot, you can also see just how close everything is packed in there.
Been liked: 1783 times
Looking great Phil, I'm sure it's about this time you wished Dragon or the other figure suppliers didn't just supply 6 footer's.
when a lot of tank crew would have been a tad bit shorter. :D
John you are so right, I have to lower the loaders seat as he just does not fit!
Phil, when you machined that lump of aluminium that is attached to the back of the mantlet to reduce the space between the mantlet and the turret, how much space did you end up with?
At the moment I am doing the same and have reached a distance of 2mm between the mantlet and the front of the turret.
I have around 2.5 mm, you don't want it to tight Vince.
