Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Shouldn't take to long to get the inner hatch detail finished although the periscope mounts need some work
There's a lot going on here
Off we go with the dimensions for Vince , the angles are a bugger.
Great files Vince
Great files Vince
I went for this version Vince in the end
Rubber sheet used for the drivers head cusion
It's not really paint drying weather right now
I'm beginning to build up the periscopes support structures, once done they are contained for life.
I think that we need a detailed drivers compartment to?
Tiny brackets to make
Awkward drilling and tapping
I'm using resin for the periscopes glass
Fiddly work but it will be on show.
Tomorrow means more detail pieces untill I'm happy, Phil don't forget those serial numbers!
More periscope detail
Bollard top coat.
Bollard top coat.
Seems a shame to remove so much material but it has to be done
I'm using Armorpax lenses
Removing Armorpax material
Final job for today is to add the hinge detail
I have turned the butt hinge detail but it's so small it's hard to see
Has liked: 1022 times
Been liked: 2093 times
Familiar photo there Phil.
Am I in trouble for using such a reference Stephen? We need your research.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Huge thanks to Stephen White for his behind the scenes support in providing photos of Centurion fine detail. He is the undoubted fountain of knowledge when it comes to adding the details that lift an Armortek model into a different league. Thanks again Stephen:wink:
I agree Mr Dawe, Stephens researched photos are the best and we couldn't do without them!
More fiddly bits associated with the periscopes, every time I look at another photo I find more to add.
Brow pads to make
Brow pads to make
Lots of small, very small parts to turn
I'm looking forward to painting these parts
I've now gone for a rubber brow pad as the vinyl is to fragile
All you see of the periscope on the left in the drivers seat
Helderluiss
Has liked: 5 times
Been liked: 169 times
Post by Helderluiss »
Impressive attention to detail. Don't take this the wrong way, but I'm going to "steal" some of your ideas :mrgreen:
Phil Dawe
Post by Phil Dawe »
Thats the beauty of this forum. the cross fertilisation of ideas helps everyone. We are very grateful for your help with the bollards!
I really don't mind anyone using any of my work for their own ends, I see it as praise indeed!
Lots done it's just very small
The very last of the fabrication
The new brow pads
The new brow pads
About as small as you can go with the lettering
I like to use a scalpel for this job
I just had to get some aluminium paint on to see if they look any good
Next job ......The unusual locking handle
Phil Dawe
Post by Phil Dawe »
Loving it Phil. The Centurion is the tank that just keeps on giving.......!
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
Only such a short time for these extremely detailed hatches,
latches and periscopes in excellent craftsmanship.
It is a real pleasure to watch.
It's Grim Up North
Thanks oliver, I do worry that I'm taking to long to produce the parts that I'm not giving value for money but a comment like yours helps no end, thankyou!
Oliver Brüninghaus
Hello Phil,
Like in art, you transform your passion into beautiful and unique models.
Unfortunately, the uniqueness can rarely be fully honored.
Keep up your outstanding work
Best
Oliver
It's Grim Up North
Cheers oliver!
Lots more fiddly work done.
Make that hatch lock!
Off we go with lots of careful filing
Only just fits
Only just fits
I'm happy with that handle
Done
Done
What colour to paint the inner periscopes surface before the glass goes on
Last job of the day is to cast the periscope glass
