Page 23 of 95
Posted: Tue Dec 10, 2019 5:31 pm
by Phil Woollard
Interesting day, I think I've cracked the non slip surface coating conundrum, and although I was not planning to start on the bazooka plates.....I have! The front plate front bracket is in the wrong place. All the plate brackets will be removed, new ones made and soldered in place with an overlap to look more like the 1/1.
The visible m3 fixings on this build will all be replaced with very much smaller fixings where ever possible.
Posted: Tue Dec 10, 2019 9:16 pm
by Richard Goodwin
Phil, you may find that the first tie down from the front on the bottom row of tie downs shouldn't be there unless of course you have a picture that says otherwise. My urban camo pics show nothing there!
Posted: Wed Dec 11, 2019 3:41 pm
by Phil Woollard
Thanks Richard I will take a look. Getting on with making the new brackets and the soldering of the lower ones.
Posted: Wed Dec 11, 2019 4:42 pm
by Richard Goodwin
Phil, since your using grease, is there any need to use a liquid gasket on the mating surfaces to seal it all in?
Posted: Wed Dec 11, 2019 5:47 pm
by Phil Woollard
Use the grease for the gasket as the mating surfaces are very good indeed, the internal grease is very viscous so it won't migrate.
Posted: Wed Dec 11, 2019 8:26 pm
by John Clarke
Richard's right about the holes, I've not seen that pair at the front on any bazooka plate in my library unless there bullet holes
Posted: Thu Dec 12, 2019 3:53 pm
by Armortek
"A tip, use the grease to hold the gearbox shaft bush in place, I managed to slot it all together first time but be careful not to drop the bush in the final drive casing."
CG0704 should be loctited in place into ES0243.
Posted: Thu Dec 12, 2019 5:50 pm
by Phil Woollard
The grease only holds it whilst it is slotted into position.
A good day spent on the bazooka plates.
Posted: Fri Dec 13, 2019 5:35 pm
by Phil Woollard
Today I have been making new bazooka brackets that attach in a more correct way over the fender/hull fillet, also installed the hull/fender fillet and some more stiffning strips the entire length of the fender, all hard to see but it is tbere.
I have tried to keep the bazooka plates nice and evenly hung but after lots of research it seems the plates were far from straight and true.
Posted: Sat Dec 14, 2019 4:55 pm
by Phil Woollard
The other brackets which are to fix the fenders to the hull, these are a little fiddly to make but do look the part.I have used 2mm rivets for the fillet strip as the bolts would have been tiny.
Now onto the rear bin.
Posted: Mon Dec 16, 2019 5:32 pm
by Phil Woollard
Working on the other side of the vehicle now.
Posted: Tue Dec 17, 2019 5:33 pm
by Phil Woollard
The rear binz , well one of them.
I did try riveting the hinge once more but the hinge just gets knocked out of line everytime, your better off bolting or using threaded rivets so you can get those shut lines right.
Posted: Wed Dec 18, 2019 4:39 pm
by Phil Woollard
The off side nearly complete, now do I add the wading hooks?
Posted: Wed Dec 18, 2019 8:12 pm
by Vince Cutajar
Enjoying your out-of-the-box solutions.
Posted: Thu Dec 19, 2019 5:22 pm
by Phil Woollard
Thanks vince, and many many thanks to Gill and Mark for all the help over the years, God bless you Gill. Kian and Monique you have much to live up to but I think you are doing just fine!
Today I have been making small parts as in the wire ropes brackets, not my favorite pass time but very necessary indeed.
