Churchill Prototype
Forum for discussions relating to the Churchill
Has liked: 2282 times
Been liked: 7196 times
Re: Churchill Prototype
I like it!
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Looking realy good 8)
Has liked: 161 times
Been liked: 830 times
Nice work Armortek! Looking really good. The tracks look great. Churchy will be an interesting beast!
Been liked: 3698 times
Testing the springs on the Churchill.
Although we calculate the theoretical spring rate and compression values, there is nothing like a real test to validate things.
A_IMG_2038 (640 x 480).JPG (224.22 KiB) Viewed 5379 times
Has liked: 1481 times
Been liked: 1687 times
And is that before or after they'd pinged all over the factory ? :lol: :lol:
Steve Stuart
Has liked: 264 times
Been liked: 195 times
Post by Steve Stuart »
The prototype is now called Zebedee!
Has liked: 1038 times
Showing your age Steve. Vorsprung durch Sprungen.
Railway wheelset anyone ?
This is one of 22 wheelsets on the Churchill
A_C3 (640 x 480).jpg (154.95 KiB) Viewed 5123 times
A_C2 (640 x 480).jpg (190.4 KiB) Viewed 5123 times
And some wheelsets from "Railway Wheelset & Brake Ltd" for comparison. Can see where the idea for the Churchill roadwheels came from ...
Railway wheelset.jpg (82.81 KiB) Viewed 5122 times
Jerry Carducci
Has liked: 3 times
Been liked: 1116 times
Post by Jerry Carducci »
There's nothing like the gleam of newly machined parts in the morning, either of one's own making or others'.
In some was seeing someone else's is better as I don't have to clean up all the nasty turnings and chips...invariably getting
something stuck in a finger... :-(
A bit more on the bogies for the Churchill.
On the real thing there are 2 types of bogies - Bogie Type A is on stations 1,2 and 11 on each side. Bogie Type B is on stations 3,4,5,6,7,8,9 and 10. The main difference between them is that the the suspension arm for Bogie Type A has additional flanges to increase its strength in order to cope with rough terrain.
The image below shows this, although it is a little hard to make out the strengthening flanges on the suspension arms. In the photograph the differences between the bogies is most obvious between stations 2 and 3.
Note that when you look at some ww2 and post war images, the bogies were occasionally mounted in incorrect positions - it was a case of needs must as mechanics made do with what they had.
Below is a image of the two types of Churchill bogies on our kit- the suspension arm is cast. On the Left is Bogie Type A and on the Right Is Bogie Type B
BOGIE TYPE A & B
BOGIE TYPE A & B
A_Bogie A and B (640 x 480).jpg (181.77 KiB) Viewed 5041 times
And some more photographs of the two of them.
BOGIE TYPE A
BOGIE TYPE A
A_Bogie A2 (640 x 480).jpg (172.48 KiB) Viewed 5041 times
BOGIE TYPE A
BOGIE TYPE A
A_Bogie Ad (640 x 480).jpg (185.96 KiB) Viewed 5041 times
BOGIE TYPE B
BOGIE TYPE B
A_Bogie B (640 x 480).jpg (195.13 KiB) Viewed 5041 times
BOGIE TYPE B
BOGIE TYPE B
A_Bogie Bd (640 x 480).jpg (194.75 KiB) Viewed 5041 times
On the Churchill, as you would have guessed from the above, there are a total of 22 bogies stations - here is a production line of them.
22 BOGIE STATIONS IN TOTAL
A_Bogie all (640 x 480).jpg (223.01 KiB) Viewed 5041 times
A good example of the wrong bogie type on station 1
Love those castings for the bogeys arms! Looking good!
A few more photos of the Churchill - showing the engine air intakes, mudguards and a front view.
A_Churchill 1 (640 x 480).jpg (214.33 KiB) Viewed 4759 times
A_Churchill 2 (640 x 480).jpg (182.31 KiB) Viewed 4759 times
A_Churchill 3 (640 x 480).jpg (165.46 KiB) Viewed 4759 times
A couple of images showing the mudguard ribs
Ribs 1.jpg (80.07 KiB) Viewed 4593 times
Ribs 2.jpg (83.54 KiB) Viewed 4593 times
Showing off the competed turret and roof details.
