Pak 43/41 rebuild
- Has liked: 20 times
- Been liked: 737 times
Re: Pak 43/41 rebuild
Started on the suspension arms, the kit ones are rather simplified, so made something more fitting
Regards Jeff- Robert E Morey
- Has liked: 161 times
- Been liked: 830 times
I love the sliding windows. Excellent details. You're going all out on this one!
Thanks Bob, having fun with this one, suspension arms made and fitted, will start on the brake details
Regards Jeff
Regards Jeff
- Been liked: 1767 times
steaming in to the Pak now Jeff, Major alterations, excellent work, regards simon.
Thanks Simon, appreciated.
Made a start on the suspension locks, these operate when the trails are in the firing position, initial observation showed that the “arm” on the trail did not line up, was the wrong angle and was short, so I am putting the locks in first then hopefully adapt the trail to fit, fingers crossed Regards Jeff
I wasn’t happy with the suspension locks I made, so discarded the lot a started again, better proportions, sturdier and all working
Regards Jeff-
Redesigned the “arm” on the trail that deploys the suspension locking bar, this now works for the full travel of the trail, first picture shows the original arm
Regards Jeff-
Finished the other trail and made a pair of steel bump stops, next will be the braking system
Regards Jeff-
Made a start on the hydraulic cylinders on the suspension, took a while to work out how it all connected, still a work in progress with detail to be added and the other side to fit
Regards Jeff-
Nearly there on the hydraulics, these were quite challenging but satisfying, no CAD, all done by eye from photos
Regards Jeff-
- Has liked: 1121 times
- Been liked: 990 times
- Has liked: 121 times
- Been liked: 258 times
Hi Jeff,
Fantastic work as always , superb details and display of craftsmanship.
Started to work out the handbrake and linkages, and it was obvious looking at photos that there was no place to fix the brake in the correct position, you can just make out in the photos that the frame had extensions on each forward corner, so I have fabricated some in steel, these just need trimming to size and fixing, I also had a go at making the flexible metal tube for the brake cable, worked well just over 2mm in diameter
Regards Jeff-
Well I am glad I did not fit the extensions I made, just found a photo of a refurbishment that shows how the front was attached to the front lower armour plate, this is only cut out on the side of the brake and also the hydraulic cylinder, who would know that was there, photo from mckaylodge.com
Regards Jeff
