Florian StuG build
- Has liked: 297 times
- Been liked: 645 times
Re: Florian StuG build
Now its going on with the interior.
First its going on with the battery. Amazing the size between 10 to 15Ah. The 10Ah is from the Famo because not enough space for bigger one.
I have in the StuG a two deck system for the electronic, so enough space for the big battery and a two speaker box for sound.
- Has liked: 78 times
- Been liked: 113 times
Hello Florian!
Have you also tested the drive with the 10Ah battery? I would be interested in whether it is sufficient, apart of course from the possible driving time.
Hi Michael,
No, I haven't tested it. It would certainly work.
My FAMO weighs about 120kg and runs with the 10Ah battery for about 30 minutes.
With the FAMO, I built the battery so, that I can change it quickly. With the StuG it is permanently installed and cannot be changed quickly. So I decided on a stronger one.
Florian
Florian
Today some more metal work at the turret.
Made the ring to connect the AP hatch
Did some more electric work today.
By the way... there are coming some new big projects for the cold days in winter
Florian
Next comes the soundbox in working process.
Florian
Hi all,
now the electrik ist nearly finish. Only thin is smoke, soundbox and barrel lifting. But the last works now previouse with one speakter.
Today is the big day rolling out the first time. Testing the tracks and shooting simulation
May you have a look here:
one more here:
Sorry for the bad quality, its a quick shoot with the mobile phone.
Cheers Florian
one more here:
Cheers Florian
- Has liked: 149 times
- Been liked: 820 times
Happy day that first test drive! That gun shot is impressive - no looking down the barrel!
Wow.
Wow.
- Been liked: 697 times
Hi Florian,
Did you use the Armortek blankfire instead of the recoil system in the stug,
or did you use a system made by yourself?
Nice video
Best regards Yves
Nice video
Best regards Yves
Thanks for the compliments
@Yves I have an own construction for about 11 shoots serie. Unfortunatly that does'nt allows thr recoil construction. - Maybe its possible with lots of work, but you can not connect the shoot time with the recoil. You would have to trigger the recoil by yourself
Cheers Florian
Cheers Florian
- Has liked: 2277 times
- Been liked: 7182 times
Holy smokes, love it!
- Has liked: 481 times
- Been liked: 408 times
Did some work at the gun mechanics. You need a strong servo but it works well.
The StuG is nearly finished now.
In time I work at the finishing paint and weathering.
Trying a real instant rust kit. The pictures are not that good as it shows real. I thing the rust is nearly perfect.
