Yes, it is!
show your Warrooms and workshop 1/6
- Has liked: 745 times
- Been liked: 359 times
- Has liked: 270 times
- Been liked: 325 times
Re: show your Warrooms and workshop 1/6
I liked the embroidery. What a wonderful thought from your daughter. Something like that would have pride of place in my workshop.
- Martin Hofmann
- Has liked: 150 times
- Been liked: 1950 times
Hi All,
here are some photos of my 2 rooms for tank building.
Between the ready tanks Tiger1, King Tiger and the other King Tiger there are lying the parts of a Sturmtiger a Jagdtiger and a StuG. So i have work for the next years
In the middle of both rooms there are hydraulic lifting tables for driving out through the windows.
Regards Martin
- Gerhard Michel
- Has liked: 3 times
- Been liked: 670 times
Hi Martin,
just I did re-read your thread about your King Tiger and its steel track links. Do you already have experiences driving this tank with its 9 teeth sprocket rings and the late steel track links in rough grounds?
Gerhard
Gerhard
- Chang
- Has liked: 16337 times
- Been liked: 477 times
Hi Martin.
Always love to see your photos. "Two rooms" and "driving out tanks through the windows" are complete news to me.
There are several 1:6 scale line drawings of Jagdtiger, Elefant with interior profile, and parts on the wall.
Amazingly I wonder did you scan, download them from books, then enlarge and print them out by some sort of drawing device, or did you obtain them from some source(s)?
I can't think of any other way to get them that large.
With regards,
Lerh Chang
With regards,
Lerh Chang
- Gerhard Michel
'Tanks driving out through the window' is also my only possibility to transfer my models. Simultaneously this is the limiting factor for the dimensions of my models. Perhaps I otherwise would have also 1/4 scale models.......
Gerhard
Gerhard
- Martin Hofmann
Hi Gerhard,
yes i was able to gain a lot of experience with the 9 teeth steel sprocket rings. The result is absolutely satisfactory. No skipping or slipping tracks - they are running absolut perfect.
Hi Chang,
thank you for your nice words. Yes i scanned the drawings from books, scaled it to 1:6 and print it out on paper.
I have a plotter who can print drawings with a hight of 900mm and a max. length of approx. 6 meters.
Hi Chang,
Regards Martin
It turns out that "down the drain" and "out the window" are totally different things!
- Gerhard Michel
Hi Martin,
nice to read. I wonder why Olaf used pointed teeth because they were even more rare than the late track links.
Gerhard
Gerhard
- Chang
Hi Martin,
after reading the latest threads about your Kingtigers with Olaf's steel tracks and your self-made 9 teeth steel sprocket rings, I went through your 2018 Kingtiger's thread, and found this photo of small hooks:
Just in case, do you still have some spares?
Lerh Chang
Lerh Chang
- Martin Hofmann
Hi Chang,
so sorry but there are no more parts to sale.
But i can send you the drawing and the step file.
Please give me your email via p
m
Regards Martin
- Chang
Hi Martin, PM sent.
Lerh Chang
Lerh Chang
- Been liked: 1818 times
As I see it, no place is off limits for a war room until told otherwise.
It did say "For better or worse" in the verbal contract
- Heiko Sattler
- Been liked: 535 times
- Has liked: 17 times
- Been liked: 26 times
Heiko. Is the truck in primer on the shelf a kit or scratch built? Looks great.
