Page 3 of 4
Re: Sherman M4A3E8 76(w) HVSS Prototype
Posted: Fri Mar 05, 2021 12:04 pm
by Tim Page
Hi all, Could the front and rear lights be turned on and off by the Benedini.
The TBS Mini has this functionality built in and as such i dont think would require an extra RC channel.
I am playing with these settings at the moment for my Panzer 3.
Posted: Mon Mar 08, 2021 9:10 am
by William Vallejo
Posted: Mon Mar 08, 2021 11:29 am
by Stephen White
Umm.... Knowledge Base anyone? The X9D is a great radio for our models but the scope for screwing up OpenTx is considerable unless there's some simple guidance.
Posted: Thu Mar 18, 2021 9:04 am
by Armortek
Some progress on the Sherman prototype. Parts are all coming together nicely - some have veeeery long run times on the machines.
Posted: Sat Mar 20, 2021 12:29 am
by Jerry Carducci
Stephen White wrote: βMon Mar 08, 2021 11:29 am
I've been experimenting, bench testing with my older Taranis (pre-2019) x9d to control the guts of my M3 Lee.
I'm using:
-2018 Taranis Plus x9d Tx ( using OpenTx 2.3)
-external XJT Tx module
-X8R receiver
-24v 24Ah LiFePo
I'm a old Mode 2 Tx user (since my earliest Futaba days in the 70's) setting defaults as AETR with my tank drive controls on the left stick- throttle and steering. I want to use the left stick for forward/ reverse and steering; it's how I've set up every tank I have.
I'm using Open TX Companion on a Win10 desktop to configure the Tx and model profile(s) via USB connection for this testing.
Modules I've attached so far are motion and sound with the focus of my tests being controlling the L/R drive motors and two geared motors
for turret functions. So far all is well mixing Rudder and throttle except some odd performance near neutral for main drive controls- one motor
insists on continuing running ever so slowly. I think I may have to implement some sort of compensating offset on the output definition or some sort of curve. Still fiddling with that. Other controls seem normal including fail safe settings (set to zero for channels 1-16)- I tested it by shutting down the transmitter with the receiver and modules still powered up and all motors came to a stop ( except for the rogue creeping mentioned above!).
I think that's about it. If someone has a profile they like that works well I'd appreciate comparing notes regarding your settings. If anyone wants a copy of mine I'm sure I could send a zipped backup of my definition as it is so far.
Posted: Sat Mar 20, 2021 6:54 am
by Stephen White
Jerry, great stuff. In order not to hijack this Sherman thread, Iβve copied your post to a new OpenTx thread in the Knowledge Base:
viewtopic.php?f=33&t=8585
Posted: Sun Mar 21, 2021 10:51 am
by Roy Beukeveld
Very impressive model! I really love the volute spring bogies, they look absolutely amazing
Posted: Fri Mar 26, 2021 5:00 pm
by Armortek
A few more prototype photos to see us into the weekend.
Posted: Sun Mar 28, 2021 4:48 am
by William Vallejo
Talk about the quintessential torture master. You do know how to churn the anticipation.
Posted: Sun Mar 28, 2021 5:00 am
by William Vallejo
Roy Beukeveld wrote: βSun Mar 21, 2021 10:51 am
I must agree. Not only was the HVSS a great improvement, I think itβs visually more pleasing to the eye.
Posted: Thu Apr 08, 2021 10:16 am
by Armortek
Some more pictures of the prototype. We ill swap out the hex heads on the light guards to button heads to make them a bit more subtle.
Tank looks so much better with the tracks on - although the tracks are not on right as the sprocket is loose and some of the rubber tyres are not on the model.
Shipping is currently looking like it will be end of May/ Early June. We are very much in the hands of suppliers at this stage - all of the machining that we can do will be finished next week - we then need to sit pretty and wait for the tracks, castings and tyres ... and the driven gear which is now 8 weeks overdue
Still - that will give us plenty of time to test out the new elevation mechanism for this model.
Posted: Thu Apr 08, 2021 11:34 am
by Tim Page
That is really coming together nicely.
It is a shame that the headlight guards have to be bolted in place when they were welded on the original tanks.
Could you not have the legs locating into holes and then epoxy in place.
This would look a lot more realistic and would still be secure.
So far everything else looks spot on and really well detailed.
Posted: Thu Apr 08, 2021 11:59 am
by William Vallejo
Tim Page wrote: βThu Apr 08, 2021 11:34 am
A very good precision welder could possibly accomplish this.
Posted: Thu Apr 08, 2021 12:05 pm
by William Vallejo
William Vallejo wrote: βThu Apr 08, 2021 11:59 am
Never mind. It appears to me that the light guards are steel.
Posted: Tue Apr 13, 2021 3:18 am
by Jerry Carducci
Having the Easy Eight is going to be sooo cool...
