Renault FT17
- Has liked: 297 times
- Been liked: 645 times
- Günter Gäbelein
- Has liked: 41 times
- Been liked: 195 times
Re: Renault FT17
Hi Yves,
I think this is the same issue as Frank had with pictures at his Centurion report. Here is a copy of the description:
by Armortek » Mon Mar 08, 2021 11:57 pm
Hi Frank, this seems to be an issue with Apple products and I am not sure what is causing it. Your pictures appear fine on Windows 10 machines, but on ipads, iphones and Macs we cannot see the images .. no matter what browser we tries.
The solution I have found after playing around for a few minutes is that the first link below does not work, but the second one does:
Code: Select all
https://dl.dropbox.com/s/6sa52so06gy4vc ... .jpg?raw=1 - DOES NOT WORK
https://dl.dropboxusercontent.com/s/6sa ... .jpg?raw=1 - WORKS
So if you change your links to this "https://dl.dropboxusercontent.com" then they should work on Apple products.
These users liked the author Armortek for the post (total 2):
Stephen White, Adrian Harris
Code: Select all
Günter
Günter
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Re: Renault FT17
Hi,
Compliments for your project, this is really impressive work!
Just a note, I see all pictures fine on iPhone Safari as well as Mac OS Safari...Günter Gäbelein wrote: ↑Fri Apr 09, 2021 5:28 pm...this seems to be an issue with Apple products and I am not sure what is causing it. Your pictures appear fine on Windows 10 machines, but on ipads, iphones and Macs we cannot see the images ...
Kind regards,
Roy
Roy
Online
- Has liked: 748 times
- Been liked: 360 times
Re: Renault FT17
Günther,
I don't see what Dropbox has to do with this - you are linking to www.panther-tanks.de. Your post from April 12th displays fine with the same site. This last one does not.
Anyway, fantastic model!
- Günter Gäbelein
Re: Renault FT17
Hi,
I don't know why the picture are not visible for you? Anyway here is a short update.
With the 2 motor drive gear there is enough room to place a mearly complete replica of the engine. After re-design of the initial engine I started printing of parts for the engine to check assembly.
Engine in place
The turret rotation gear is in place
To be continued.
Engine in place
To be continued.
Günter
Günter
Online
Awesome build! I like the way you use 3D print creatively and hard metal where appropriate, combining the two.
Re: Renault FT17
Ah, Armortek style!
