ELEFANTE
- Has liked: 9 times
- Been liked: 124 times
Re: ELEFANTE
But with some milling work, scratching the periscopes and some aluminium pieces... was fixed
- Chang
- Has liked: 15415 times
- Been liked: 403 times
Re: ELEFANTE
Hola Alberto,
How nice to see the diamond pattern aluminium sheet and little front-fender springs were added in your Elefant.
I have done the addings too. For me they are the must details that can't be ignored, and I shall say that you have done it beautifully.
BTW, what are these and what are they for?
Lerh Chang
![Idea :idea:](./images/smilies/icon_idea.gif)
Lerh Chang
Re: ELEFANTE
Hello Chang !
Well thanks to you we have the dimond patern !... thanks a lot.
Ok the screws you see are the ones to hold the super structure to the main chassis, son I will explain what we do...
Re: ELEFANTE
Meanwhile, other detail finnished, inside of the muzle brake... in the second picture the muzle brake is empty
Re: ELEFANTE
The idea is to hide all the bolts that hold from the exterior all the plates, after that we try to use the ones that the Elefat has in real life, we change the internal metallic angles and switch with a aluminium ones thiker of course to tap it, so, unscrewing the bolts you see in the pictures is the only thing you need to remove the entire engine deck ![Wink :wink:](./images/smilies/icon_wink.gif)
