Martin's King Tiger
Martin Hofmann
Has liked: 151 times
Been liked: 2014 times
Re: Martin's King Tiger
Post by Martin Hofmann »
here comes the next photos from the front cover with the hatches and self made castle nuts M2. The surface of the thick sheets is treated with Mr. Surfacer 500.
Regards Martin
Martin Hofmann
here comes some more photos from the cupola and the modified mudguards.
Regards Martin
Martin Hofmann
here i start with the turret and the new muzzle brake fresh from Armortek ( with 3 pieces ) with some modifications of the openings.
Regards Martin
Martin Hofmann
here is some progress of the hull, started with the blank plates after sand blasting
Regards Martin
Has liked: 1495 times
Been liked: 1699 times
It looks like you're making good progress :D
Is that one of Phil's armour piercing rounds in the glacis plate ?
Has liked: 2282 times
Been liked: 7196 times
Adrian I am more concerned about his feet in the shower pic!
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
Phil Woollard wrote:Adrian I am more concerned about his feet in the shower pic!
I agree. Germany had already gone metric by the time the Kingtiger was built. They should be meters and not feet. :D
Good one Mark :D
Martin Hofmann
Hello Phil,
Hello Mark,
here comes some more metric photos from the hull without feet!
i hope you don't miss it.
Regards Martin
Martin Hofmann
the hull starts slowly looking like a hull with all the holders and the welding seams - kilometers of that in more than one row..........
Regards Martin
Martin Hofmann
But a King Tiger also needs some road wheels and suspension arms.
Here i start with the arms, the wheels and the idlers.
have much fun with the photos.
Regards Martin
Martin Hofmann
here are the next photos from the road wheels and the idlers..........
i also drilled and pinned the suspension arms with dowel pins.
Regards Martin
Martin Hofmann
Here comes the final drive housing and the sprockets with some modifications like radii and some grinding for making a casting surface.
Regards Martin
Martin Hofmann
here are the casting surfaces with Mr. Surfacer 500 and also the casting numbers of the sprockets.
Regards Martin
Martin Hofmann
i have made some new sprocket rings with 9 teeth not 18 for the steel track, because the old one was aluminium - not so good for a steel track!!
There are also some details of the hub caps.
Regards Martin
